Punto443 wrote:First one looks like the aircon cycling switch thing.
loot wrote:No idea but if you look closely you should hopefully see part numbers which you can Google
Vanman2 wrote:Does anyone know what the 2 Vacuum switches in the photos are called and their uses? Is there a hose vacuum hose plumbing diagram on here? 2001 Mark 6 VH 2.4 turbo diesel. Thanks
wojciech wrote:Vanman2 wrote:Does anyone know what the 2 Vacuum switches in the photos are called and their uses? Is there a hose vacuum hose plumbing diagram on here? 2001 Mark 6 VH 2.4 turbo diesel. Thanks
First photo - it is EGR Vacuum Control Valve, is operated by PWM signals from PCM . Nr 1100027 (YC1Q-9E882-AA) or 1127411 (YC1Q-9E882-BA). Usually applied in model tddi with Bosch pomp, in CR Delphi tdci was little bit different two valves (one for EGR, second for turbocompressor).
Look pic.1 and Pic.2.
In your van Vacuum Control Valve should have on the top third connection terminal for pipe from air filter - system need to suck clean air. It is broken - I think...
On second photo is shown part nr PBT-GF30 (look Pic.3) - it is Mass Air Flow Sensor, but it can be called Emission Control Sensor - on Pic.2 it can be nr 2 4449664 (YC15-9S428-AA). In this case I am not sure for 100%...
https://www.catcar.info/ford/?lang=en&l ... NCsyNzI%3D
Vanman2 wrote: what makes the heater work - vacuum - via solenoid?
wojciech wrote:Vanman2 wrote: what makes the heater work - vacuum - via solenoid?
In 2,0 FWD with AC warm water valve (nr 10) is controlled by vacuum and vacum solenoid. Propably by PWM signal, but I'm not sure, because front heating has electric temperature control actuator.
https://www.catcar.info/ford/?lang=en&l ... MTkyKzA%3D
Vans with rear compartment heating heater is controlled by electric water valve (nr 2 in second link) by PWM signal. On that I am sure, because actuator works only for change blowing direction.
https://www.catcar.info/ford/?lang=en&l ... NzUyKzA%3D
