FORD TRANSIT MK6 2001 2.4 DI RWD.
Hello everybody. Two years ago I had starting issues. Ended up been the dmf. At the time I had a new battery/starter motor. New dmf and clutch fitted.
Present day and the van won't start. I've taken the starter motor (rtx) off and bench tested it. It spins from the test and also clicks and shaft rises as power connected. Now I'm confused. Is this starter working? No swarf in housing of starter motor upon removal.
The symptoms when fitted. It would try and start van by turning over then accompanied by a constant whinning noise until I turn the key to the off position in ignition.
I'm rather confused. Thanks for any help and reading this.
