LOCKED REAR DOOR
LOCKED REAR DOOR
Postby Moggins » Tue Jun 05, 2018 8:47 am
Hi guys, having some issues with my rear door. It's locked shut and won't open. The side door only opens from the inside so that cannot be opened. Was going to take it to a garage but I'm not paying hundreds. I have a feeling that cables have been swashed between the door and the frame deadlock in the door. Debating drilling out the door handle and hooking the cable in an attempt to open it. I'm getting the door replaced because of a large dent which is unrepairable. Anyone got any ideas on how to get it open would be a big help
Moggins
Re: LOCKED REAR DOOR
Postby richgold » Tue Jun 05, 2018 3:59 pm
Get in thru side door. Remove ply-lining or door card from left rear door as you look at it from the inside. From in there it should be obvious to you what to fiddle with to open the door. Unless its dealocked whereas you will need some of this:
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby scas » Tue Jun 05, 2018 4:23 pm
when you try to unlock it either with the key of the fob -does the rear offside door lock make a noise
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Postby Moggins » Wed Jun 06, 2018 9:26 am
When I unlock it I can hear the side door unlock but hear nothing from the rear door. Still can’t get in the side door because of the grommet missing on the cable system. If there’s no way to open the rear door then plan B is to cut through the bulkhead, reach in and manually open the side door then but a bloody grommet in
Moggins
Postby Herts » Wed Jun 06, 2018 6:27 pm
Or cut a hole in the roof (easy to repair with fibre glass) i'm sure some asre wash has a step by step guide.
:lol: :lol: :lol: :lol:
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby Moggins » Thu Jun 07, 2018 8:50 am
Best to cut through the bulkhead as it’s coming out anyway and isn’t being resold. Hopefully it’ll work
Moggins
