Cant pair more than 1 key fob MK6
Postby Kriegar » Wed Jun 13, 2018 9:00 pm
So I got 2 new 3 button key fobs for my transit and every time I pair one up it kicks the other one off.
I have tried taking the other set of keys out of range and have even removed the battery to make sure that the other fob isnt being reset.
Any ideas?
Kriegar
Postby blue estate » Wed Jun 13, 2018 9:28 pm
You’re doing it all wrong
When in pair mode pair both remotes at same time as pair mode wipes current remote as well
72plt MG 5 ev estate Battery car
blue estate
Re: Cant pair more than 1 key fob MK6
Postby Altransit » Wed Jun 13, 2018 10:02 pm
blue estate wrote:You’re doing it all wrong
He means one immediately after the other, not at the same time :wink:
Postby Kriegar » Mon Jun 18, 2018 4:39 pm
That did the trick. Was doing both at the same time or on separate sequences, not one after the other on the same sequence!
Thanks :D
Kriegar
