MK7 2.4 Cuts out at junction.
Re: MK7 2.4 Cuts out at junction.
Postby ned » Mon Jun 18, 2018 7:04 pm
Dirty dog had this issue with his mk7 I think he had a wiring fault, think its in his project/progress thread. N
viewtopic.php?f=27&t=172632&start=15#p1540899
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby v8dave » Mon Jun 18, 2018 7:26 pm
If the pump learn works but you can't get it to complete the injector learn then from my experience the next step is a leak off test of the injectors.
v8dave
Postby twin--turbo » Fri Jun 22, 2018 8:07 pm
SCV replaced, only really tricky part was the one 10mm bolt below the inlet manifold "Inlet".
Did not have my laptop with me to do the learn, but she fired straight up and for the few moments she was running was stable.
Will do the learn and report back after a few miles...
TT
twin--turbo
Postby daraioj » Fri Jun 22, 2018 9:30 pm
twin--turbo wrote:SCV replaced, only really tricky part was the one 10mm bolt below the inlet manifold "Inlet".
TT
Did you replace it without removing the manifold?
I guess you saved yourself an awful sight :)
2010 2.4L RWD 100ps MT75 LWB High Roof
daraioj
Postby twin--turbo » Fri Jun 22, 2018 9:42 pm
no the manifold has to come off unless you're triple jointed and lying on the windscreen with the bonnet off..
Did not even look at the manifold in any detail.
TT
twin--turbo
Postby twin--turbo » Fri Jun 22, 2018 9:44 pm
want it at least running right and MOT'd by the end of the month as I want to take my Jaguar off the road for a month to sort a load of little items out without having to rush.
TT
twin--turbo
Postby twin--turbo » Sat Jun 23, 2018 1:54 pm
Pump learn done this morning, took longer than I imagined , partly as I had to leave it running for 10-15mins to get up to 55C!
Anyway it's done the pump learn without any problems and whilst it was warming up the idle was solid.
Traveld 4 miles without it cutting out at a junction but only time will tell, it's on a 90 mile run tomorrow with 4-5 stops so will see how we fare..
TT
twin--turbo
Postby dirtydog » Sat Jun 23, 2018 2:12 pm
ned wrote:Dirty dog had this issue with his mk7 I think he had a wiring fault, think its in his project/progress thread. N
Yeah mine was a chafed wiring loom next to the abs pump
dirtydog
Postby daraioj » Sat Jun 23, 2018 3:25 pm
Sorry to hijack the thread but how did you clean your inlet manifold? Did you clean the ports too? Thanks in advance
daraioj
Postby twin--turbo » Sat Jun 23, 2018 4:45 pm
I did not bother cleaning mine, i can't see it helping that much anyway.
TT
twin--turbo
Postby daraioj » Sat Jun 23, 2018 9:03 pm
twin--turbo wrote:I did not bother cleaning mine, i can't see it helping that much anyway.
TT
Mine is not as bad as I thought it'd be but still the first two or three ports have a good 3mm wall of crap. I don't know how big a difference it would make but I wouldn't mind cleaning as much as I can off it while I'm at it.
daraioj
Postby twin--turbo » Sun Jun 24, 2018 12:24 pm
80 miles done including driving back through town and not cut out :)
Think, fingers crossed it was nice and simple ;)
TT
twin--turbo
