Yo guys, I would appreciate some help and advice on this one.
My tranny is on an 07 plate and is 2.2 85 t260, ive done some investigation by removing the air box and cleaning thouroughly around the injectors and found that I have oil bypassing the rubber seals around the injector and the cam cover? then pooling and eventually running down the front of the engine onto me driveway..bloody mess!.
This is only happenning on the left injector, its not vast but annoying! the other three are fine.
I asked a couple of peeps and they said the injectors would have to come out to enable new seals to be fitted..but..it appears that this is not as simple as I thought and could be a tad expensive? (I saw the video on utube where they used a mini JCB to pull the injector out!..ouch)...so more advice from other "peeps" who said that I could use sillicone gasket seal daubed around the leaking injector seal (after scrouplously cleaning and degreasing) and that would do the trick.
They said the sillicone was heat proof and "up" to the job...whats your thoughts..is it that a bona fide quick fix?..the old gal has done 180.000 without to much problem over the last 7 years..over to you for advice.
Regards
Husheechee
