P0546
P0546
Postby rsjon » Fri Jun 15, 2018 10:09 pm
2013 2.2RWD with P0546 EGR Temp sensor circuit high.
Is this referring to the temp sensor before the cat that has wiring issues or a temp sensor on the EGR that I haven't dealt with before?
Thanks,
Jon.
rsjon
Re: P0546
Postby rsjon » Sun Jun 17, 2018 9:44 am
I have worked this out and will share it now:
P0546 refers to pre cat Lambda sensor in the exhaust.
I checked all the wiring and connectors carefully but in my case it was an open circuit sensor (green sleeve) causing the problem.
Both sensors are supplied with 5 volts so check this first, then check resistance of sensors whilst very gently warming them with a blow torch...obviously removed and in a vice.
Resistance should be several Mega Ohm when cold, gradually dropping in resistance to at least several Kilo ohm when hot.
Hope this helps somebody!
Replacement tomorrow and happy days!
Jon.
rsjon
Users browsing this forum: AWDan
