Punto443 wrote:Egr cooler and oil cooler are far more common failures than headgaskets on these,
bambi mk 1 wrote:What year
Airthies wrote:The water cooled EGR would be my bet. Suspecting and assuming it's a RWD the EGR is (looking into the engine bay from the front) down to the right rear of the engine. I shouldn't be too hard to spot if it's water cooled (pipes on either side of the body of It),
Quickest and simplest way to check if it's at fault is to remove pipes and either blank or join hoses.
If there's a crack in the EGR then it could let coolant out into exhaust as it's running and lack of pressure in system coupled with Loss of coolant will help to cause overheating.
As mentioned head gaskets are not a common problem but not impossible.
If your just losing water but not getting oil in the coolant then oil cooler can be ruled out.
Good luck and enjoy the surf.
