Chuggy wrote:Starter motor contacts?
do you mean starter motor terminals? or ignition switch starter contacts?
Starter motor terminals are on the starter, and I would leave the ignition switch alone if you don't know what you're doing and just fit a new one if its needed.
Chug
Matt_bott wrote:I get this on my 2.2 - if i stick my foot on the throttle whilst turning it over it starts - if not i just get clicks!!
If i have done a decent run then I dont get click and it just starts. If the van has sat for a day or 2 or has just be used around town it get more clicks
Its had a new battery but admittedly it was just a cheap one!
Karst wrote:At a recent service they told me 2 of the cells in my battery are dead, could that have something to do with it?
At the same time as this clicking it often cuts power to the radio to the extent that it resets the clock to 00:00/
Altransit wrote:So there you go, it's the battery needs replacing.
dirtydog wrote:Yep as simple as that, new battery will sort it. As for the clicks I presume it's the starter motor solenoid clicking but there's not enough power to spin the motor
Users browsing this forum: knobby1
