Smoke at low revs
Smoke at low revs
Postby Drtcmm » Wed Jun 20, 2018 9:57 am
Hi all, so last year I blanked off the EGR valve on my 2010 trend. It did throw the management light up but it ran great. With the MOT coming up I though I better sort it out so I put a new EGR it. Now the van seems low on power just as you touch the throttle lags a little then after the first bit it's fine. Also when the engine under load at the bottom of the rev range I get black smoke but then it clears. Any ideas what this could be? Thanks
Drtcmm
Re: Smoke at low revs
Postby bambi mk 1 » Wed Jun 20, 2018 10:04 am
Is the light still on :?: Get the codes read make note of them clear and read again after a drive :wink:
bambi mk 1
Postby Drtcmm » Wed Jun 20, 2018 1:40 pm
The light was reset after the new EGR was fitted. It was on due to the EGR being blanked off.
Drtcmm
Postby Drtcmm » Thu Jun 21, 2018 9:03 am
Is it possible that last year I had the fuel reteach done with the EGR blanked off. Would putting the EGR back into the system throw the fuelling off now?
Drtcmm
Users browsing this forum: Google [Bot], knobby1
