Timing cover inspection panel oil leak
Timing cover leak
Postby Stevetransit04 » Sat Jun 09, 2018 3:22 pm
Very slight leak from bottom of timing cover is it an easy fix only a couple of drops a day do I just live with it Mark 6 2.5 rear wheel drive
Stevetransit04
Re: Timing cover leak
Postby scas » Sat Jun 09, 2018 4:01 pm
its either the front crank seal-easy and quick or the timing cover itself-easy but takes a bit longer. clean it with brake cleaner to see which it is
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Postby Stevetransit04 » Wed Jun 20, 2018 10:51 am
Thanks for advice on closer inspection I think it's coming from the timing cover inspection circle plastic thing
Stevetransit04
Postby Stevetransit04 » Wed Jun 20, 2018 11:06 am
2004 2.5 rear wheel drive oil leak coming from the round inspection Cup thing at the bottom of this round thing on the timing cover is oil slight drip down to sump few trips on the floor how do I stop this inspection panel from leaking please
Stevetransit04
Re: Timing cover inspection panel oil leak
Postby Stevetransit04 » Wed Jun 20, 2018 11:19 am
Mark 6 transit by the way
Stevetransit04
Postby knobby1 » Wed Jun 20, 2018 11:15 pm
Stevetransit04 wrote:Mark 6 transit by the way
It will be a 2.4 not 2.5..!!
Postby v8dave » Thu Jun 21, 2018 6:46 am
The cover is a bayonet fitting.
Turn it anti clockwise to remove.
Degrease everything properly.
Apply sealer to the groove around the edge of the cover and refit.
Or buy a new cover.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby Stevetransit04 » Thu Jun 21, 2018 11:31 am
Thanks for the info mate how do I remove it I've heard whack it with a screwdriver is there a less brutal way
Stevetransit04
