"Best" engine oil (additive)...?
Postby Karst » Thu Jun 21, 2018 8:29 am
Hi Folks,
I've tried doing a search for "best engine oil" but the search software does not like it.
I know there's a lot of opinions about engine oil. Some say they are all the same, others say this oil or that additive is best. The last engine oil I used was Bardahl after being convinced of its merits (apparently it is (one of?) the only truly fully synthetic oils on the market. The others labelled "fully synthetic" are not, the courts ruled that description was not a statement of content, but a name only for the oil. Wonder who got a backhander there?)
Any offers on the "best" oil for a 2007 Mk7 Transit?
Any offers on the best oil + additive? How about Lucas Heavy Duty Oil Stabiliser?
Ford Transit Mk 7 Panel van, ex-posty's, 57 reg, 2007. Duratorq TDCI 2.2 (85PS)
Karst
Re: "Best" engine oil (additive)...?
Postby bigjohnthomas » Thu Jun 21, 2018 8:47 am
Put any old shite in as long as you change it regularly the van will rot away before the engine is run in :D
And I'm a scientist you know
bigjohnthomas
Postby dumper » Thu Jun 21, 2018 12:08 pm
I stick with ford surplyed and no additives
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Karst » Thu Jun 21, 2018 7:30 pm
I mean technically speaking, anything which gives the oil the capacity to stick to the cylinder walls for the longest time will result in the least engine wear, right?
That's why I used to use Castrol Magnatec for diesels. I know it's not magnetic, but the additives in the oil would make it stick and it would hopefully still be up the insides of the cylinders at the next start up.
Isn't it?
Karst
Postby dumper » Thu Jun 21, 2018 8:05 pm
Not sure but I think that fords oil is magnatec .I worked fo one of England’s major bus companies and they ran the engines on some cheap oil and the engines all did well over 500,000 miles but every bus on the fleet had a oil and filter every 3 months no matter what miles they did
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
dumper
Postby abiolayunis » Sun Jun 24, 2018 4:20 pm
bigjohnthomas wrote:Put any old shite in as long as you change it regularly the van will rot away before the engine is run in :D
I strongly agree. Constant replacement is the key.
Sent from my TECNO F2 using Tapatalk
abiolayunis
Postby richgold » Mon Jun 25, 2018 1:01 pm
I did a combined half-a-million miles in my last 2 vans (one of which was a Transit) run on whatever oil they used to have in a barrel at the dodgy garage I used.
No problems with engine wear to report, infact the Sprinter engine still pulled like a train at 310k when I sold it.
Just change the oil either at the scheduled interval or before and you'll be fine.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
