changing tappets
changing tappets
Postby scas » Fri Jun 22, 2018 12:12 pm
most of my tappets are solid so i was going to change them. i can push them back into the follower with vice grips and most spin around freely but how do you get them out of the follower? 2.4 mk6
06 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 115 remapped by martyn
04 mk6 2.4 di 90
05 mk6 2.4 di 115
new 06 mk6 2.4 di 115
new 00 mk6 2.4 di 125
can you see a pattern
scas
Re: changing tappets
Postby Jim Archer » Fri Jun 22, 2018 8:28 pm
They should be solid unless the oil feed hole is uncovered, or they are so knackered they won't stay pumped up.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby knobby1 » Sat Jun 23, 2018 8:28 am
scas wrote:most of my tappets are solid so i was going to change them. i can push them back into the follower with vice grips and most spin around freely but how do you get them out of the follower? 2.4 mk6
Can you get them out..?? I'm not sure they come out......even if you could, I don't think you can buy them separately.
Postby scas » Sat Jun 23, 2018 11:29 am
https://www.ebay.ie/itm/x8-FORD-TRANSIT ... Sw5ZtaXyjz
are they really meant to be solid? i would have thought there should be a bit of give in them, but im just guessing
04 mk6 2.4 di 90
05 mk6 2.4 di 115
scas
