Timing Chain Tensioner Replacement
Postby Tcollings » Sat Jun 23, 2018 10:49 am
Hi Guys,
I've got a mk6 75psi Duratorq engine -150k on the clock. I've had a host of problems but more recently heard a bit of chain rattle when cranking the engine and so think its probably wise to change the tensioner asap. Do I need to change the whole lot, i.e. chain, sprockets, tensioner and guides, or can I get away with just changing the tensioner and guides. I'm a poor student so if I can avoid changing the whole lot that would be ideal. Sorry if this has been asked before.
Thanks,
Tom
2001 mk6 LWB Duratorq 2.4L RWD
Tcollings
Re: Timing Chain Tensioner Replacement
Postby amlav » Sat Jun 23, 2018 11:08 am
Taking in account that it is a bit of a job I would say might as well change the lot and have peace of mind .
Once the cover is off it is easy to change things . Getting the cover off is the time consuming job .
amlav
Postby abiolayunis » Sun Jun 24, 2018 4:16 pm
I suggest you change the tensioner (if it is truly faulty), the guides and the chain only. The sprockets are hardly faulty.
Sent from my TECNO F2 using Tapatalk
abiolayunis
Postby amlav » Mon Jun 25, 2018 8:21 am
abiolayunis wrote:I suggest you change the tensioner (if it is truly faulty), the guides and the chain only. The sprockets are hardly faulty.
+1 Yep . more likely sprockets are ok .
amlav
