Washer Pump Fault
Washer Pump Fault
Postby dantranvan » Sat Jun 23, 2018 8:39 pm
Know it's not the fuse as a)I've checked it and b)I still get the wipers come on when pushing the button.
Is there any easy way of checking what is at fault out of the stalk, wiring and pump itself?
TIA
dantranvan
Re: Washer Pump Fault
Postby dirtydog » Sat Jun 23, 2018 10:00 pm
If the wipers are still coming on I'd say the stalk is working ok. I had a similar issue a little while ago and it was actually the terminals on the pump had rusted through and come off
dirtydog
Postby knobby1 » Sat Jun 23, 2018 11:36 pm
Sometimes the pump water inlet clogs up with crud.
Postby Brains_transit » Sat Jun 23, 2018 11:45 pm
I fixed a mk7 and the fault was chaffed wires in the engine bay. Check for voltage at the pump when the stalks pushed
Brains_transit
Postby dantranvan » Sun Jun 24, 2018 3:20 pm
Brains_transit wrote:I fixed a mk7 and the fault was chaffed wires in the engine bay. Check for voltage at the pump when the stalks pushed
I'll have to dig the multimeter out
knobby1 wrote:Sometimes the pump water inlet clogs up with crud.
If this was the case, should I be able to hear the pump working when the button is pushed?
dantranvan
Postby knobby1 » Mon Jun 25, 2018 1:08 am
Aye...yes you should....so if you can't hear it, you must have a wiring or motor fault as the others have suggested.
