MK7 Rear spring shackle
Postby Rabsy » Sun Jul 15, 2018 8:59 pm
Does anyone have the tightening torque settings for rear spring (especially the top bolt on the shackle)? I think i read on the forum that the front spring bolt is 225Nm and the rear bolt is 115Nm - I don't see any mention of the top shackle bolt at the rear?
My van is Mk7 year 2007 350 Lwb.
Thanks in advance!
Rabsy
Re: MK7 Rear spring shackle
Postby Brains_transit » Sun Jul 15, 2018 9:02 pm
I just put them tight as I can as it's a pivot
Brains_transit
Postby david.reid83 » Sun Jul 15, 2018 9:42 pm
Hope this helps and it’s Nm
david.reid83
Postby Rabsy » Sun Jul 15, 2018 10:31 pm
Mentions everything except the top shackle bolt at the rear - It must be the same as the lower shackle bolt (rear spring bolt)
Rabsy
Postby david.reid83 » Sun Jul 15, 2018 11:04 pm
Rabsy wrote:Mentions everything except the top shackle bolt at the rear - It must be the same as the lower shackle bolt (rear spring bolt)
No probs that’s out the Haynes manual I just got
david.reid83
Re: Solar powered welding masks any good?
Postby Airthies » Sun Jul 15, 2018 11:38 pm
Usually just Ft.Nm
Bikes, yes, a few bikes.
V86+patch
V86.04
X-Prog
C81
Airthies
Postby v8dave » Mon Jul 16, 2018 11:27 am
Both bolts are the same size.
ETIS says both are the same torque at 115 Nm.
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
