v8dave wrote:Check which bcm you have, electronic tachographs are only supported by B, C or D variants.
Wadey wrote:v8dave wrote:Check which bcm you have, electronic tachographs are only supported by B, C or D variants.
If he runs it as a stand alone system with a separate sender that won’t make a difference to the bcm will it??
v8dave wrote:Wadey wrote:v8dave wrote:Check which bcm you have, electronic tachographs are only supported by B, C or D variants.
Transits with those bcm variants apparently have the wiring to power the tacho already, but you still need the speed sensor and it's cable as that only connects to the tacho.
