Which wires for custom amplifier
Postby Kriegar » Tue Jul 17, 2018 7:05 pm
So Im trying to hook up an aftermarket amp to my mk6 and have ripped out the old radio.
So far when I hook it up and switch the ignition on it just heats up... so clearly Im connecting the damn thing up wrong.
Can anyone point me in the right direction as to which color wires I should be using?
Kriegar
Re: Which wires for custom amplifier
Postby richgold » Tue Jul 17, 2018 8:19 pm
What stereo and what amp?
Please post a pic of your amp connections. And alything else you think might be relevant.
Its pretty simple wiring an amp up I'm sure when we've seen it whatever is wrong will be easily spotted.
Unless your amp is fooked.
Vauxhall Nova GTE 1300 1988 in Royal Blue - My garage ornament.
Volkswagen Crafter 136 LWB 2016 back in white and staying that way! SOLD!!!
Transit 115 Jumbo 2010 - SOLD!
Audi TT 225 Roadster - SOLD!
Mercedes Sprinter 311 LWB 2004 - SOLD!
richgold
Postby Kriegar » Tue Jul 17, 2018 8:46 pm
Its a "vibe slick" amp. I just googled a picture of the back of it because im lazy.
I initially googled around to find which wire was which but I still can't seem to get it working. which color wires should I be using for what?
Kriegar
Postby richgold » Tue Jul 17, 2018 8:54 pm
From left to right:
GND = wire to van body close to the amp
REM = connect to blue wire from back of stereo or an ignition live wire from anywhere else, this turns the amp on when when it receieves power (provided everthing else is connected correctly)
+12v = +12v from battery (with an inline fuse rated at 25a)
For the GND and +12v connections you must use a good guage of cable as this is where the power is. If you dont have cable for 30a or more then dont wire it up, it could easily burn your cables if you use lower rated cable.
Speaker connections should be self explanitory.
richgold
Postby richgold » Thu Jul 19, 2018 5:10 pm
So does it work?
I couldnt sleep last night not knowing.
richgold
Postby Kriegar » Thu Jul 19, 2018 5:16 pm
Haha thanks for the response, ill try and get a look at it tonight! :D
Kriegar
Postby Kriegar » Fri Jul 20, 2018 9:16 pm
Right no same as before.
I have been connecting the 12v+ to the orange/black wire, the ground wire to one of the green/black wires and then the remote wire to the yellow/blue wire.
It may not help that they are speaker wires that im using to bridge the wires, but I have been doubling them up to avoid them burning out until I get some proper wire.
What I found odd is that its the ground wire that's heating up, whether or not I connect it to the ground wire on the stereo or the chassis of the van.
The amp also also heats up so im wondering if I have borked it!
Any suggestions?
Kriegar
Postby twin--turbo » Fri Jul 20, 2018 10:07 pm
take it to a pro.
twin--turbo
Postby richgold » Fri Jul 20, 2018 10:36 pm
No one does wiring by wire colour. I presume you dont have a meter and you're guessing what these wires are?
What are the wires you mention and what do they supply?
If they are part of the original vehicle loom then don't wire an amp to them because you'll almost certainly burn them out. You could also cause serious damage to the vehicle loom, killing your van. Do not use doubled up speaker wire as electricity will not use both wires effectively, it will start to burn the shortest one. Also an amp should never be grounded back through the stereo loom, thats absolute madness. If you read what I wrote above I said to take it to the van body as near to the amp as possible, meaning use the shortest run of suitable wire to a nice earth point.
If you take an "I can do it" attitude to something you're not sure of then you'll come a cropper.
Any wiring for power for an amp should be totally new, be comprised of the correct wire and fuse and not use any part of the original vehicle loom.
richgold
Postby Kriegar » Sat Jul 21, 2018 1:21 am
Ah right fair enough. I had read online which wire does what and read that you can get wiring harnesses to connect the original stereo wires to an aftermarket amp or just cut the wires (which I have done).
I am taking the van in to get new tires tomorrow so will speak to the mechanic about it and see if they can help. I did try grounding to the van and taking the power from the +12v off the battery but will try it again if the garage can't help.
I didn't think it would be so complicated just to get power to the damn thing!
Kriegar
Postby richgold » Sat Jul 21, 2018 1:43 am
Kriegar wrote:I didn't think it would be so complicated just to get power to the damn thing!
It isnt.
richgold
Postby Kriegar » Wed Jul 25, 2018 8:57 pm
I have tried wiring this to the battery like you suggested and still nothing :/
Im wondering if the amp is just not working.
I even tried connecting the negative terminal to the remote connection and still nothing.
I have a new el cheapo amp too so will have to give that a bash too and that should highlight if its my fault or the amp.
Kriegar
Postby richgold » Wed Jul 25, 2018 9:05 pm
Kriegar wrote:I even tried connecting the negative terminal to the remote connection and still nothing.
Why would you do that? Thats never going to work. There's no wonder its not working and If you continue to touch wires on connections just to see if they work then your almost certainly going to damage something soon, thats if you havent already.
Here is how to wire it again. If it you wire it up as I've said (not swapping the connections round or doing it however you think) it wil work, if it isnt already fooked.
The remote connection needs wiring to battery positive.
The 12v+ to battery positive
GND to battery negative.
If you can wire it up like that and still nothing then bin it.
richgold
Postby richgold » Wed Jul 25, 2018 9:51 pm
Have you checked the fuses on the amp?
Sent from my SM-J330FN using Tapatalk
richgold
Postby Punto443 » Wed Jul 25, 2018 10:03 pm
I think you should just leave it alone, clearly you do not have the skill set for this.
pay someone who knows how to do it, before you do some real damage!
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
