No oil pressure light on dash 2.0 Diesel
Postby JesterRB » Tue Jul 17, 2018 7:52 pm
Hello All!!
I ve owned transit 4 years and it’s been fantastic, but noticed the other day the oil pressure light on the dash has stopped working? I’ve shorted out, nothing, there 5volts to the pressure switch. I’ve taken the dash out but seems like you can’t replace the filaments. The 3ngine runs good oil pressure when i checked with an external gauge. Anyone else had an issue or could point me in the direction of a good wiring diagram?
Cheers!
JesterRB
Re: No oil pressure light on dash 2.0 Diesel
Postby v8dave » Tue Jul 17, 2018 8:11 pm
mk6 or mk7 ?
What year ?
v8dave
Postby bambi mk 1 » Tue Jul 17, 2018 8:34 pm
v8dave wrote:mk6 or mk7 ?
What year ?
A 2 litre mk7 now that would be rare :wink: Leds in dash 03 to 06 :wink: :wink:
OP have you earthed the wire down at the switch to a clean earth :?:
bambi mk 1
Postby JesterRB » Tue Jul 17, 2018 8:44 pm
It’s 2005 mk6. Yes I’ve shorted the wire to earth with no joy?! Can you replace or check then leds in the dash?
JesterRB
Postby bambi mk 1 » Tue Jul 17, 2018 8:53 pm
Check the engine loom where it joins the engine compartment loom at the fuse box for power .I very much doubt it will be the led .
bambi mk 1
Postby JesterRB » Tue Jul 17, 2018 9:05 pm
bambi mk 1 wrote:Check the engine loom where it joins the engine compartment loom at the fuse box for power .I very much doubt it will be the led .
Ok will do, is it a 5v feed from the ECU or 12v? Thanks!!
JesterRB
Postby ABA » Tue Jul 17, 2018 10:04 pm
try your solder joints on the back of dash board sooner or later you will loose all the clocks all the gages and its all down to solder joints onj the back of the dash board
ABA
Postby JesterRB » Wed Jul 18, 2018 5:36 pm
After a morning of stripping out the dash and checking resistances and voltages the conclusion is the wiring is damaged somewhere in the engine bay. So I've wired in a separate light on the dash using ignition live and the original pressure switch as Earth. Works well!
Thanks to all who replied
JesterRB
Postby ned » Wed Jul 18, 2018 6:31 pm
Does the oil pressure switch wiring join the pump loom and travel over/behind the starter motor? If so that'll be where the fault is, in the wiring loom around the starter. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Users browsing this forum: hauteneur
