Matt246801 wrote:Update on this guys, replaced the valves genuine ford and fuel pressure is still all over the place am I looking at a pump now? Only things left are a pump or air in the fuel lines? Getting really fed up of this now any help appreciated
Matt246801 wrote:I’m pretty sure it said procedure aborted, It’s not letting whatever procedure it is finish because of the fluctuating rail pressure? I’ve checked the clear pipe and it looks fine, still the same fault code too p0089 fuel pressure
Matt246801 wrote:It definitely runs better since the valves were changed and it’s running alright just now as before it was always going into limp mode or not letting me rev properly, It judders at low revs every so often but I just want to get to the bottom of it
Users browsing this forum: Google Adsense [Bot], metalworker0, scotth93
