ECU Part No - what swaps?
Postby Jim Archer » Fri Jul 20, 2018 7:01 pm
Having chased my self up my own arse with my 2010 Jumbos' not starting issue :roll: , the only thing I haven't now swapped/replaced several times is the ECU. What do I need to have Part No wise to match? Present one is AC11 - 12A650 - CB.
At cranking, the rail pressure comes up, it fires 1 cylinder, rail pressure falls on it's arse, couple of turns for the pressure to come back up, fires 1 cylinder, rail pressure drops out again. No fault codes other than stuff being disconnected and over cranking. Fires and runs instantly all the time it's getting a bit of sniff. As far as IDS is concerned there appears nothing wrong other than not holding rail pressure - I'm no expert with IDS so not sure what I'm looking at to be honest.
The only other thing attached to the engine I haven't done is change the main vehicle loom, but surely that would show a code?
If I track down a suitable ECU, what is involved with pairing it with immobiliser, BCM, ABS, etc?
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Re: ECU Part No - what swaps?
Postby knobby1 » Fri Jul 20, 2018 11:40 pm
I'm guessing your PRV has blown....they don't throw up a fault code.
Postby andz327 » Fri Jul 20, 2018 11:49 pm
knobby1 wrote:I'm guessing your PRV has blown....they don't throw up a fault code.
+1 Defo sounds like the prv bastardo
andz327
Postby Jim Archer » Sat Jul 21, 2018 6:59 am
Had a new Ford PRV, plus a whole known good rail assy from a running donor - and that runs fine with my rail.
Nothing coming from the valve outlet when cranking.
Jim
Jim Archer
Postby v8dave » Sat Jul 21, 2018 12:05 pm
If it runs ok with a donor fuel rail but not with yours then I'd suggest the fuel pressure sensor.
However you've seen fuel pressure when cranking so there must be some signal coming from the sensor back to the ecu.
What rail pressure do you get when cranking ?
mk7 08reg 2.4 T350 LWB MHR RWD
mk6 X reg 2.4 T350 LWB MHR RWD - scrapped
mk4 J reg 2.5 L300 LWB MHR RWD - sold on
Notice a trend there ? not too big and not too small
v8dave
Postby Jim Archer » Sun Jul 22, 2018 6:47 am
That's the thing, it doesn't run with the donor rail. The donor van (a 125) runs happily with my rail.
I can't recall what the cranking pressure it reaches is - 26000(?) - as it only very briefly holds it, and ECU away for 10 days for testing.
Jim
Jim Archer
Postby loot » Sun Jul 22, 2018 8:27 am
Have you got ids? Have you tried doing a pcm update? I generally find that a successful update means (generally) that the pcm is ok as the calibration gets verified and loaded.
You can get another pcm and get it working on your van with ids and pats, 2 keys most likely.
You should be able to get another pcm AC11 (60 plate?) And if you feel that your pcm is ok then you can do a module replacement suck and blow to your new pcm but you can't be 100% sure that any fault won't get sent across. Installing new software to a pcm is slightly more tricky.
Before all that you need to read fault codes with forscan and or ids.
You need to be sure that everything is ok, the fuel rail pressure will come on then drop if there is a problem with electronics, scv, battery, module etc and also the injectors turned off to save engine.
So I wouldn't look too much at the rail pressure as a fault.
Did you check every fuse?
Did you bypass the fuel filter head?
Crank and cam sync?
Ignition key?
Batteries?
Relays r4/r6/r8?
So the pcm i believe is.
AC11
Year
12A650
What it is ie pcm
CB
Power variant ie 125 ps? (The calibration actually)
Ids map here
loot
Postby bambi mk 1 » Sun Jul 22, 2018 10:30 am
Jim have you swapped crank sensor as Loot says :?: I would also be checking the chain.To eliminate the ecu swap the ecu and bcm and blue bit of key it should run even if its not the same ecu .
bambi mk 1
Postby Jim Archer » Mon Jul 23, 2018 7:39 am
Haven't checked crank sensor or timing as live data says sync'd. Surely it would throw a code if not?
Hadn't considered swapping the 125 bits over as assumed mine being a 140 would be different enough for calibrations etc to prevent it running anyway.
Jim
Jim Archer
