Have a set of clocks to change( my vehicle -clocks identical),-What is the procedure within IDS ?
Assume once clocks installed -then hook up VCM- then what? will it automatically detect replacement clocks and then guide you through set up?
davyjcb wrote:If your not worried about the milage being exactly the same provided that it's similar and not thousands out there's no need to programme them unless your going from level 1 (standard) to level 2 ( trip comp, outside temp etc)
