Not sure about the mk8 vans but assuming your looking at moving to the mk7?
The difference in turbo's depends on what PS the engine is.
The simplest way to get more HP is getting a remap of the PCM (powertrain control module) which is an electronic way of getting more from your engine.
BUT the best thing to start with is a van that has a decent PS to start with.
As far as turbo's are concerned the lower ps vans are a mechanical waste gate control. The higher ps vans (above 115ps I think) are VNT turbo's which have an electronic unit which varies the vanes inside the turbo to adjust the boost pressure.
In modern electronicly controlled engines it's not quite as simple as whacking on a bigger turbo to give you more oomph since the engine management is not programmed to see more flow or pressure in the intake.
Hope this helps but would be useful to give more info on what van(s) your looking at to give better advice as there's lots of options out there
Sent from my anu5 using crapatalk
2008 350LWB 115PS ex fitters van "retired"
Bikes, yes, a few bikes.
V86+patchV86.04X-ProgC81
