Normal noise? Leaking injectors? Related?
Postby prototype3 » Sun Aug 05, 2018 9:40 pm
Hi all,
13 plate MK7 Euro 5 125 2.2
Van drives fine, noisy when cold and less noisy when warmed up. Got a tapping noise on idle (see video) which disappears when revved, also noticed some misting around one pair of injectors (on the left in the photo, 1 and 4?). Can't actually tell if it's oil or fuel, doesn't really smell like either (untrained nose).
SO,
Should I be worried about the noise?
Should I be doing the injector seals?
Should I just turn up the radio and crack on with life?
https://youtu.be/wKufD7ev8E8
Cheers :D
2013 Ford Transit 2.2 125 300 Euro5
prototype3
Re: Normal noise? Leaking injectors? Related?
Postby loot » Thu Jun 20, 2019 7:58 pm
Did this get fixed?
Ids map here
loot
Postby davyjcb » Thu Jun 20, 2019 8:30 pm
Them not too hard to do the injector washers are only about £ 4 each from Ford hell of a lot cheaper than the euro 4 ones 6 nm + 360 job done
96 escort 55 van gone
98 smiley mwb semi high gone
01 90/350 mwb semi high roof gone
05 135/350 lwb semi high roof gone
10 85/260 swb low roof leader gone
09 140/350 lwb semi high fwd
11 115/330 mwb semi high roof
davyjcb
Postby loot » Thu Jun 20, 2019 10:11 pm
Cheers. :D
Ids map here
loot
Postby prototype3 » Thu Jul 04, 2019 12:22 pm
loot wrote:Did this get fixed?
Almost a year down the line and it's still on the to do list... Hasn't got any worse though :roll:
prototype3
Postby Altransit » Thu Jul 04, 2019 7:58 pm
I have the same problem, I did one pair, now the others are leaking, and I'm not getting round to getting it done :roll:
If you leave them, the carbon build up will make the injectors difficult to remove, (one of my original pair was very hard to get out) which could cause problems if an injector needs to be changed. It's one of those jobs that's not urgent, but it does need to be done :mrgreen:
