Murphy281 wrote:Wojciech what do u think it was if it’s not the imv valve coz when it was running it felt like it was not getting fuel
Murphy281 wrote:No it never went in to limp mode or anything like that it just ran sluggish an more on hills or put the foot down in 2 an 3 gear when you put the foot down it missed like hell then was ok if u took foot off a bit but couldn’t get to the bottom of wot was doing it. It’s in ma mates garage the now he’s gona try an c wots maken it not start hope it’s not the injectors coz they r a bit pricey new.
Wojciech what do u think it was if it’s not the imv valve coz when it was running it felt like it was not getting fuel as was chapping now an again an it wasent like that before an when it done it on my tddi it was the fuel selonid so thout it was the same on this one so a thout it was have u had this before on a van
Don't suppose you tried puting a genuine Ford tdci fuel filter on it before all the messing with injectors ?Murphy281 wrote:I would do that at the turbo side but it dosent start up an run an when a use easy start it runs lumpy as hell an no throttle an when it runs out the engine is rocking bk an forward an the battery light comes on when it is. I will go down to the garage urs at tomorrow an c how they have got on an c if they can do the checks with the ids if not l will try an get someone who can thanks for all your help hopefully I can get it bk gunning again
Maybe fiter is choked with tdci always use proper ford filterMurphy281 wrote:I haven’t done anything with the injectors yet andz327 an it was the same fuel filter that was on it before it was doing it would it been that causing the van to run a bit lump on hills coz it’s not a genuine ford one that’s on it
Only thing that’s bn done with the injectors is reprogrammed back in as wen put it on the snap on code reader it said injectors wasent coded in so done that and it still didn’t run so don’t know if that was anything to do with it or not
Users browsing this forum: Altransit, Billysal, Google [Bot], Google Adsense [Bot]
