ids help needed
ids help needed
Postby reaperkinqs » Fri Aug 10, 2018 7:02 pm
hi all i have a VXDIAG VCX NANO running ids 109.1 all works perfect the problem is when i try and do car parameters it starts reading but say bcmii mast module error and some other bits as well wondering if anyone can help me as i could do with getting it working i tryed on one transit and it worked tryed 3more and wont let me do it i have a pic of the error
https://ibb.co/c5ohQp
reaperkinqs
Re: ids help needed
Postby loot » Sat Aug 11, 2018 7:44 pm
Looks like it doesn't have access to the module :-(
What year van is it? If it is before 2013 try v86-v94 ids.
Ids map here
loot
Re: ids help needed
Postby reaperkinqs » Sat Aug 11, 2018 7:55 pm
loot wrote:Looks like it doesn't have access to the module :-(
its a 2010 crew cab tipper 2.4 rwd
ive tryed it on loads of other and no joy i only had i working on one van but it still wouldnt let me load it back on
reaperkinqs
Re: ids help needed
Postby loot » Sat Aug 11, 2018 8:30 pm
I don't like those ids things, I prefer vcm2 hq or you can spend 10 quid and get a modified elm327 then download forscan and register to activate it but that's free.
It'll do most things that ids will.
IG you say you've tried your vx on loads but no joy then I'd bin it personally :-(
Ids map here
loot
Re: ids help needed
Postby reaperkinqs » Sat Aug 11, 2018 10:10 pm
loot wrote:I don't like those ids things, I prefer vcm2 hq or you can spend 10 quid and get a modified elm327 then download forscan and register to activate it but that's free.
ok cheers for the info
reaperkinqs
Re: ids help needed
Postby reaperkinqs » Sun Aug 19, 2018 7:54 pm
hi loot just wondered if u could help me i tryed to load as built data today day from car parameter and it fail i all so tryed to program the bcmii and that failed to now ever since that failed the abs light is stuck on and traction control i done self test and it saying abs software incapability do u no or have any idea y it doing this, i guess the Vxdiag Vcx Nano im using cant do things like this so wondering whats the best vcm2 i should buy then i can bin this Vxdiag Vcx Nano (sh*t)
Thanks in advance
reaperkinqs
Re: ids help needed
Postby loot » Sun Aug 19, 2018 8:21 pm
Answered your pm.
Would probably take me 1.5 2 hours to sort that all out and install the pcm/bcm so trying to explain it and including the installation and use of ids would be paramount :-( the info is on this forum but sporadic at best unfortunately.
You can buy a modified elm327 with switch (eBay-under 20gbp)then online for software called forscan free. and get it registered.
That will read codes and configure the van for you.
You are jumping in the deep end with this project I think. :wink:
Ids map here
loot
Re: ids help needed
Postby reaperkinqs » Sun Aug 19, 2018 8:35 pm
loot wrote:Answered your pm.
all i need to do is what i said in the pm thats all can elm327 do what i need it to
cheers
reaperkinqs
Re: ids help needed
Postby loot » Sun Aug 19, 2018 8:36 pm
I believe it will yes but I have limited experience of forscan, if anyone else is good with it and can help??
Ids map here
loot
Re: ids help needed
Postby reaperkinqs » Sun Aug 19, 2018 8:47 pm
loot wrote:I believe it will yes but I have limited experience of forscan, if anyone else is good with it and can help??
ok could u explain how i would trick the vin over do i just enter the correct vin when i connect the ids to the vehicle the reporg the bcm or do i change the vin in the as built data
reaperkinqs
Re: ids help needed
Postby Punto443 » Sun Aug 19, 2018 9:51 pm
You may be trying to instal features that are not supported by your modules?
Eg. hill assist etc?
2018 Renault trafic
my old mk7
my old mk6
my xr3i
Punto443
Re: ids help needed
Postby Cider Andy » Fri Sep 28, 2018 10:55 am
reaperkinqs wrote:...I have a VXDIAG VCX NANO running ids 109.1 all works perfect...
I bought one of those, with v106.2 running in a VMWare virtual machine. I found that, even though the laptop was within the recommended spec, it just wasn't up to it whilst running as a virtual machine. Of the three vans I tried it on it could only read the Car Configuration Parameters off one of them, but didn't always fail with the same error!
So I loaded a native v86.04 on the same laptop and the VCX Nano has worked faultlessly so far. My feeling is the laptop performance spec is critical: it seems to fail if there is any data underrun.
Drink moderately, eat healthily, exercise regularly, die anyway.
Cider Andy
Re: ids help needed
Postby knobby1 » Sat Sep 29, 2018 7:41 am
Cider Andy wrote:I bought one of those, with v106.2 running in a VMWare virtual machine. I found that, even though the laptop was within the recommended spec, it just wasn't up to it whilst running as a virtual machine. Of the three vans I tried it on it could only read the Car Configuration Parameters off one of them, but didn't always fail with the same error!
This is why many of us now run Forscan...much more user friendly and will run on any old piece of junk lappy.
Users browsing this forum: Google Adsense [Bot], philbomk7
