Fill fuel filter open all injectors turn it over until fuel squirting out of pipes , tighten pipes and it should start, if you have fuel at pipes and not starting it maybe a timing chain jumped problemAshleyWilliams wrote:Gents, I’m after some more advice,
Ok I’ve got myself a hand pump but only an 8mm one I’m assuming the correct size is 12mm. I’m guessing the hand bulb pump goes in before the filter? If so when I take it out won’t the fuel just drop back down to the tank again?
Ash
AshleyWilliams wrote:Hi Andy,
Is this the case even if my van hasn’t got a lift pump from the tank? Which I don’t think mine has?
Ash
knobby1 wrote:AshleyWilliams wrote:Hi Andy,
Ash
None of the Mk6 or Mk7 diesels have a lift pump in the tank.
ned wrote:No but the very early mk6 tddi's had one on the filter (higher ps models) N
AshleyWilliams wrote:Ok so I don’t need to pump the fuel up from the tank? Just fill the filter, crack the injectors and crank it over?
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot], richardstubbs
