Drilling front bumper reenforcement
Postby ned » Sun Aug 12, 2018 7:16 pm
Is it OK to drill 2 holes in the front bumper reenforcement thing, I asked because I need to drill 2 X 16mm holes (1 each side) to fit the headlight washer jets into (the bit that sits under the bumper) mucho grassyarse. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Re: Drilling front bumper reenforcement
Postby bigjohnthomas » Sun Aug 12, 2018 7:23 pm
16mm drill thats a big drill
doyou have a reduced shank ? :P
wink
you should be able to just push your finger through that :lol:
bigjohnthomas
Postby ned » Sun Aug 12, 2018 7:39 pm
I need to stick the bottom of these into the metal bit,
A reduced shank you say :? I have a 16mm metal hole cutter that goes on a arbor thingy :D if that makes sense. N
ned
Postby bigjohnthomas » Sun Aug 12, 2018 7:45 pm
fancy engineering equipment you have then
just drill it
it will be alright :)
nothing to worry about :D
all is good :D
perfect :P
bigjohnthomas
Postby ned » Sun Aug 12, 2018 7:50 pm
8) that all I needed, quality engineering advise :D I was temped to get the pop up washer jets from an Audi but couldn't get the buggers off it :( N
ned
Postby Altransit » Sun Aug 12, 2018 7:50 pm
You're bound to be contravening some EU law regarding it's crash tested structural integrity, but then, who cares anyway :P :mrgreen: :lol:
Crack on :D :shock:
Postby ned » Sun Aug 12, 2018 7:54 pm
:lol: :lol: who need EU rule's anyway :wink: the bit above the bumper is rubber coated so soft on pedestrians that might bump into them :lol: :lol: N
ned
Postby bigjohnthomas » Sun Aug 12, 2018 7:57 pm
Perhaps you should wait until after brexit then
You don't want Jean Paul spunker banging on you door in the middle of the night sausages in hand
bigjohnthomas
Postby ned » Sun Aug 12, 2018 8:04 pm
:shock: brexit still isn't over :shock: :roll: oh hairy ball sack, I'll send farmer pigdick to Mr R S Spunker :wink: :lol: N
ned
Postby Brains_transit » Mon Aug 13, 2018 5:58 pm
I had water sloshing about inside mine
Brains_transit
Postby ned » Mon Aug 13, 2018 6:04 pm
When it's rained I get a nice waterfall when turning right :lol: think its from the windscreen gutter but could be from the bumper support, how did the water get in there. N
ned
Postby the dutch guy » Mon Aug 13, 2018 6:47 pm
if i recall a old MK6 at work had a face plate for a snow plow bolted to that beam.
Mk6 SWB TDCI 125
the dutch guy
Postby ned » Mon Aug 13, 2018 8:04 pm
What's a snow plough :shock: :lol: I suppose you could bolt anything to it :D wonder if I could fit some paintball guns somewhere to shoot the non indicating a***holes :shock: :lol: :lol: :x N
ned
Postby the dutch guy » Mon Aug 13, 2018 9:53 pm
ned wrote:What's a snow plough
its german for snowiematron. :mrgreen:
Mk6 SWB TDCI 125
the dutch guy
Postby loot » Mon Aug 13, 2018 10:10 pm
Looks a bit underpowered that motor mate.
What about this :P
https://hobbyking.com/en_us/turnigy-ca8 ... tore=en_us
That's clear the crap off 8)
Ids map here
loot
