jumbodrw wrote:Hi Guys,
Thank for the add, as you can see i'm new on here..
Right my very first question!!
I've fitted rather large tyres to my van(i'm always in quarries etc need extra height) my van is a 2008 twin wheel 350 jumbo, the tyres I've fitted are 7.50R x 16 that measure 2530 mm rolling circumference or 784mm diameter.
Now when i look in IDS the biggest tyres listed are 2205mm is there anyway to put in my own measurements on this ?
Not too much of a problem as the speedo is only reading about 10% slow
Or can i put a sensor in the gearbox as i have wiring and alter IDS to get it to read this, Then alter the diff Ratio to get my speedo back.
Now i know this isn't a common mod but any help would be appreciated.
Neil
jumbodrw wrote:Thanks for your reply,
When i was under the van yesterday i saw i had wiring down to the speed sensor hole is this same on all mk7 rwd's, i was just wondering if there was a setting maybe on engineering ids that would allow me to use this sensor for speed.
I must let you know that i haven't used ids much so i'm still getting round to all it's functions.
if i try to alter the tyre size or circumference i just get ABS lights on
But there is a setting that says
Customers own size in tyre size
So this had me thinking .
But if i select this there is nowhere to put and size into the box.
Neil
jumbodrw wrote:Hi Ned,
This is the rear
i will get the front when i get it back on its wheels after the clutch change,
Neil
