loot wrote:The leak off test is tickover for 4 mins and between 25ml and 40ml.
If they showed that amount at 1 minute then I'd fit the 2 new valves with these injectors left in, do a pcm update if you can then a fuel pump learn then an injector pilot learn. If they both succeed then you do another leak off test under the above conditions and see if it is more accurate.
Note, I bought an injector leak off kit and the bottles had no holes in nor did the seals fit tightly so diesel was spewing all over the place So I used my home made kit which worked well enough but basically the leak off just wants to drip into the bottles afaik.
Anyway.
I suspect that the pilot learn may fail which will bring on a permanent warning light until it succeeds.
This indicates a small leak somewhere (maybe!) Or most likely the injector/s are knackered
But if it all passes then check leak off and hope they are under 40ml.
Pfjones do recon/testing/new injectors I believe.
I prefer new unless the van is just a cronk.
Could be other problems to though.
Post fault codes etc if you need more help.
iiPaul wrote:Thanks for the quick reply, well I’m not sure we performed the leak off correctly then as the van cut out after 1.30 down to no fuel.. (blanked the pump off at the pump where the black pipe connects to) didn’t want to clamp the leak off pipes and break one as they seem brittle
How do I perform a pcm update on forscan?
I dunno what to do now as I need the van for work and don’t wanna cause problems again as the last time I done a injector learn it failed and kept cutting out all the time
v8dave wrote:iiPaul wrote:Thanks for the quick reply, well I’m not sure we performed the leak off correctly then as the van cut out after 1.30 down to no fuel.. (blanked the pump off at the pump where the black pipe connects to) didn’t want to clamp the leak off pipes and break one as they seem brittle
You have to blank the leak-off pipework completely otherwise it lets air into the fuel system and the engine stops.
Don't block the leak-off connection on the fuel pump, it has to remain connected to the fuel filter as the pump has leaks as well as the injectors.
If the volumes you got at 1:30 were at idle I think you'll need four injectors.
Are parts out of Ford ??iiPaul wrote:v8dave wrote:iiPaul wrote:Thanks for the quick reply, well I’m not sure we performed the leak off correctly then as the van cut out after 1.30 down to no fuel.. (blanked the pump off at the pump where the black pipe connects to) didn’t want to clamp the leak off pipes and break one as they seem brittle
So confirmed the leak off was done incorrectly, will that effect the result of leak off test?
What will be the worst case if I fit the new valves and do the updates? Will the van still drive?
iiPaul wrote:Got a genuine for maf to go in, but denso prv and scv
knobby1 wrote:iiPaul wrote:Got a genuine for maf to go in, but denso prv and scv
Forget the rail pressure sensor and the MAF and/or MAP sensors, they rarely fail...but the SCV and PRV must be genuine Ford/Denso items or the learns will probably fail.
Injector leak-off should be done with engine fully warmed up, at idle for 4mins, limit is 25-40ml, if it's a fair bit over this the pilot learns will probably fail.
Where did you buy your genuine prv scv from mate ?iiPaul wrote:knobby1 wrote:iiPaul wrote:Got a genuine for maf to go in, but denso prv and scv
Yeah got genuine denso scv and prv ready to fit, question is do I fit it now and if it fails the learns will I be able to drive it
v8dave wrote:If you change the valves you will probably not notice any change from the way it currently drives.
If you attempt the learns and they fail you will have the engine warning light on. It will mask any other faults.
If you have checked for codes with forscan and it's clear then my advise is don't change the valves until the leak-off has been done correctly and any fault identified from that dealt with.
Remember that the leak-off limits are the expected range of leakage, the important part is that all four injectors be within 10% of the mean leakage.
I when through this with my van a few years back.
iiPaul wrote:Pf Jones I believe mate
