andz327 wrote:Its says for lwb which is shorter than a jumbo maybe thats the problem mate.......thats a beast of a van
hah thanks mate
only had it 4/5 months, just had the front tires and alignment done on it yesterday, £200 quid for two yokos and an alignment! crazy money...
dieselhead123 wrote:Hi there, the panel in the link you posted is intended for use opposite the side loading door on a LWB van, the part you require is not available from pattern suppliers, however......
The part in your posted link does have the same x-section, (on the vertical plane) as the part you need to repair, so is a good panel to start with, although some 'tin work' will be required in the rear bumper recess and where it meets your rear wheel arch.
We can supply you with the same part as in your link for £38 but there will be a postage/delivery charge to add.
If you feel you need further advice on repairing this part of your van or on other body parts you might need then please call our workshop on the number below and ask to speak to Tim.
Hope this helps,
LCS
That is some very useful information! thanks for letting me know, do you guys also do patches of sheet metal too? need some about 2footx2foot for another job on it, also I'm not too far away from you guys, I'm up in chelmsford
Thanks!
Rob
