Loom shouldn't be near wheel arch, you'll just need to follow loom from the contact pads and check for a break just in case the removed the wires to be ultra safe and breaks on brittle wires can happenmaushawk wrote:Just got my van back from having its rusty arch repaired, and the central locking isn't detecting the sliding door. I can see the connector is in place inside the door pillar, I've cleaned the contacts and it looks like all the wiring inside the door is intact. The garage is shrugging it off but it was working when I handed it over, and the welding work was done in the same area as the wires that hook up to the door connector. I think there's a possibility they cut through the loom. Is there anything else fairly simple I can check? For now I've had to lock it with the manual switch.
