Jay2018 wrote:Your second pictures shows your Turbo leaking oil? Turbo seals might be buggered, turbo might be on it's way out. You should check the turbo because you haven't mentioned the oil there. The oil could be leaking down the engine and making it look like you have other leaks elsewhere...
hackmagic wrote:Thanks for the replies Jay2018 and Lord Knobrot.
I did include the picture in case someone picked up on the oil leak there, i wasn't sure what that component was tbh. The picture with the sump is on the other side of the engine (as i'm sure you know) so i didn't think the leaks were related. I'll check if i go for a second viewing. Elsewhere people have mentioned that the mk6 T135 was very unreliable so i am kind of concerned i'd be in for problems if i did take it.
ned wrote:its not Delphi's fault but the fact that the common rail was new technology at the time
ned wrote:Anyway mk7 user where have you been hiding N
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot]
