Engine swap
Engine swap
Postby Chris 6169 » Sat Aug 18, 2018 11:54 pm
2004transit 2.4 swapped engine starts and cuts out after 5seconds engine came out of 2004transit125 350my
Truck is 115 2004with digital clocks the doner van as analogue clocks swapped ecu and transponder but only runs for 5 seconds and cuts out any help please
Chris 6169
Re: Engine swap
Postby dumper » Sun Aug 19, 2018 8:08 am
Theirs two sensors on the flywheel or front of the engine that if you get the plugs on the wrong way round check them first van will do this I’ve read on hear
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Re: Engine swap
Postby Chris 6169 » Tue Aug 21, 2018 9:25 am
Do the numbers on the pump have to match as it won't code to my ecu
Chris 6169
Re: Engine swap
Postby Altransit » Tue Aug 21, 2018 10:52 am
Chris 6169 wrote:Do the numbers on the pump have to match as it won't code to my ecu
If it's not coded correctly, it won't fire up at all, as the immobiliser will prevent it.
Firing and cutting out sounds like the crank sensor, so I would look at the two plugs at the back of the engine, as advised above :idea:
Re: Engine swap
Postby Chris 6169 » Tue Aug 21, 2018 5:50 pm
Number on old pump ends in 4040new pump ends with 5040
Chris 6169
ECU PROBLEMS
Postby Chris 6169 » Fri Aug 24, 2018 4:28 pm
Put pump on and the ecu won't code with pump some one as tryed to code and as coded my key to another ecu so my ecu will not work key
Chris 6169
