Does it have air con ? Air con relay is same as starter relay so you could try swapping relays over
Sent from my SM-G975F using Tapatalk
andz327 wrote:Does it have air con ? Air con relay is same as starter relay so you could try swapping relays over
andz327 wrote:Have you done ignition switch yet??
tranmx2 wrote:The starter solenoid engages a switch which puts power to the starter motor.
The switch is often two copper plates on which elec arching occurs overtime the carbon build up causes more arching and contact is not made.
The switch is inside the solenoid housing which is the round thing on the starter motor, to which the small red wire is attached - it is earthed via the earth strap from the motor to the eng block.
DMac wrote:Hi
Did you ever get this sorted?, have something similar only mine starts, clicks several times and hunts until warmed, changed starter six months ago and on battery number 3 in 3 years. Still clicks runs fine otherwise
DMac wrote:Hi
Mr_Viking wrote:
It was the PCM that was faulty, funny enough it came up with a DTC for PCM programming error when i got the injector codes for the new PCM. Wish it did that at the start lol oh well all working now
