MinorMatt wrote:I have a new ign switch on the way already...
I really am having to do a parts cannon on this.
A new crank sensor hasn't helped.
With the new glowies its so close to starting.... its still crank for ages, will run half a second and then cut out. I'm going to play silly arses tomorrow and put and electric pump inline with the fuel feed to the filter tomorrow - but I doubt it will help at all.
Getting right pissed off with it
knobby1 wrote:MinorMatt wrote:I have a new ign switch on the way already...
What fuel rail pressure are you getting during cranking..??
MinorMatt wrote:A lad at the workshop loaned me his rail pressure gauge jobby - which has some blanks
Despite passing the leak off and learns it appears injector 1 was a bit dodgy. Blanking it on the rail gave good pressure.
I have put a PF Jones injector in it and I know have really good rail pressure... but its taking a little but to build it up and its still coughing and spluttering and not going.
With a bit of squirt it fired up okayish and its now sat running. I need to code the new injector and do learns etc. Hopefully running it for a bit will purge any air and I will be able to programme the injector in and do the learns and it should be ok???
MinorMatt wrote:b*stard thing!!!!
Users browsing this forum: Jp71
