metalworker0 wrote:Yes i see them
https://i.ebayimg.com/images/g/zhoAAOSw ... -l1600.jpg
Truth is i don't know ..they may just get ground up or they may do damage
Timing cover is one use only ..so you'll need a new one - looks like there are two holes into the timing section where they could escape into it.
if they fell between the chain and the tensioner guides they may have broke the guides.
The bits are likely to float in oil , so may get sucked up into the strainer
So if you are over concerned, sump will have to come off to clean strainer.
if its done a high mileage , it may be the ideal time to change the camchain.
Think these things are to support the rocker cover and make it flex less should anyone should lean on it, as it would crack without them.
Trouble is as this plastic ages it becomes brittle ..and that's what's happened.
FitnessB wrote:After trying both injectors in cylinder 2 both make no difference to idle when unplugged but the other 3 do so I've atleast worked out cylinder 2 is the problem
knobby1 wrote:FitnessB wrote:After trying both injectors in cylinder 2 both make no difference to idle when unplugged but the other 3 do so I've atleast worked out cylinder 2 is the problem
A tapping noise and no combustion on #2 may point to a poorly rocker or poor wiring to the injector. Would pay to pop rocker cover off and have a good look. Rocker ladder is independant of cams so no issue with disturbing the cam timing.
FitnessB wrote:I run out of daylight today but did get the rocker cover off.
I had someone turn the key while i had a look but didn't see anything obvious and fuel was pumping out so i
decided to leave it until tomorrow.
Whats the best way to turn the fuel off?
Its a 2011 model.
I did notice some of those small wheels have side to side movement and others didn't but i have no experience with them so dunno whats a normal amount.
Are the rocker ladder bolts one time use stretch bolts do you know?
metalworker0 wrote:plastic melted on the injectors ,..sorry don't know, unless that tube got ground up and ended up down there
