2. Managed to wriggle a screwdriver up to the solenoid and shorted across the two big nuts while a willing helper turned the key - there was nothing from the solenoid. No 'big wack", not even a click.
Shorting across the two large nuts - is what the solenoid does when it is operated when the key is turned to start the engine - the solenoid is an electricaly operated switch. The starter key does not need to be turned to the start position.
Shorting across the two bigh nuts - checks that there is power and that the starter does turn.
https://www.youtube.com/watch?v=kFsl5r34lCIA wire from the B+ with a fuse to the thin wire connection on the solenoid could cause the solenoid to operate. If the solenoid does not operate it could be considered that the solenoid is damaged.
If the solenoid is good the starter motor could turn and rotate the engine.
Managed to wriggle a screwdriver up to the solenoid and shorted across the two big nuts. There's usually a flash doing this - if no flash likely there's no power in the big red wire or and the link to the motor, motor to earth is not good.
2012 MK 7 E 5 100-350 3.5 XLWB RWD Duratorq 2.2L CR TC 14 DSL 100/125 PS E5 DPF BCM PCM RCM
Was DRRB 74 KW 100 HP 100 cv. Now CYR5 125 HP. PCM could still be for 100 HP.
There's more letters after a Transit than a military man
