knobby1 wrote:Jason2 wrote:Surely if the timing was so far out that the pistons were hitting the valves there would be starting problems, smoke and diesel knock, fault codes ??
I want to be sure before I strip it down again to check timing !
If cam timing was out, it would never start, they need cam/crank sync to start.
Fuel pump doesn't need to be timed as it's TDCi.
Were the learns done after engine was up and running..??
Tapping noise could be a poorly hydraulic valve lash adjuster.
Thanks for your reply .
The learns were done for the injectors .can’t do it for thé vcm solenoid job with my
Diagnostic tool .
Tried listening to the adjusters with a piece of pipe onto
the rocker cover but can’t here anything nasty .
