Ok peeps need some guidance with some fault codes on my Mk7 2013 2.2 RWD 125 350.
Code: P0670 - Glow Plug Control Module 1 Control Circuit / Open. Status -28 So, the van generally starts fine (kept inside though) It stutters and splutters a bit after first glow plug light on dash. If I ‘glow plug’ twice straight away in a row on the dash she’ll fire straight up. I believe there are different, codes for individual glow plugs whereas above points to the module. I think the module is underneath the coolant expansion tank.
Access is pants on RWD 2.2 but I can get to two of the glow plug contacts. I get 10v instantaneously when the key is turned but this go straight to 0-2v on either glow plug I can get at. I don’t really want to take the induction manifold off to get to the glow plugs unless I have to. Are aftermarket GPCM any good or need to be genuine? Anyone had the same code?
Code: P2599 – status -24 and then -50 Turbocharger Boost Control Position Sensor 'A' Performance - Stuck High. I have had this twice in the last couple of weeks. The van goes into limp with an engine malfunction display on the dash. Pulled over, switched off for five minutes and then away again fine. Now the actuator is an absolute sod to see let alone get to on a RWD 2.2 I can’t hear any chattering or the actuator going mad but it’s very hard to see the linkage – I’ll struggle to get to the linkage to get the C clip off to see if there’s any play in it. Is it possible to do a calibration/learn of the actuator in FORscan? Determine max and min and rest itself?
Few bits of history may help. 170k miles – I’ve had it over a year but only done about 4k miles in it. When I first got it it intermittently hunted and lost power – or at least generally seemed pants on power but some times worse than others. Intercooler was blocked up so cleaned that out but was seeing the boost pipe collapsing intime with the surging/hunting and this corresponded with slight hunting on the rev counter. I put in a cheap turbo pressure gauge and was getting up to 1.5bar pressure but I could see it fluctuate/loos boost which led me to EGR valve. I replaced with a Hella unit but no difference. In the end I had the EGR deleted in software. The unit is unplugged currently. It is not blacked off, just working against its own return spring. No hunting or anything since then. At the same time I had software bumped to make it around 150hp. It drives how I expect a transit to now although sometimes when towing it feels sluggish at low revs – got to keep it in the turbo to actually get it to shift on. Probably have about 400kg of tools in it so far from limit. Tows occasionally.
Code: B1047 - Rear Fog Lamp Control Switch. Additional Fault Symptom (:29):
In the last two weeks I’ve been having the fog lamp illuminate on the dash when I’ve been pressing my brake pedal and sometimes with my indicator – so I think I’ve got a dodgy earth somewhere – any tips.
Code: U0155 - Lost Communication With The Instrument Panel Cluster Control Module
Module: Restraint Control Module
