Hello, Both reverse lights are faulty and not working. I checked the light bulb and everything was normal. Is the error coming from the sensor? Can I change it myself?
M3Stig wrote:if its the reverse switch which it sounds like is a common problem, can be found under the front bumper ontop of the gear box with a 21mm socket and part from either ford or euro car parts, dead easy to change
marcofreeman wrote:Hello, Both reverse lights are faulty and not working. I checked the light bulb and everything was normal. Is the error coming from the sensor? Can I change it myself?
Not if its fwdknobby1 wrote:M3Stig wrote:if its the reverse switch which it sounds like is a common problem, can be found under the front bumper ontop of the gear box with a 21mm socket and part from either ford or euro car parts, dead easy to change
Not if it's a RWD. He hasn't told us what model transit he has.
