After my van (Mk7 100 t260 fwd 2.2l swb 2013) getting some work done(spring>brake pipes> a cailliper ) my van had been sitting for a couple weeks whlist my dad worked away at it.
eventually got the brakes bleed and went to start it and the van was dead. so we used a booster and it started no problem
The other night i went to tesco and when i came out the battery was dead, my dad came down with the booster again and it started no problem, after chatting for about 5 mins i wwnt to jump back in and the battery light had came on.
i said to my dad and he follow me up the road, with the van cutting out before getting out the car park.
So the next day i hooked up forscan, and the battery was showing 10v-ish so wee assumed it was the battery, so i replaced it today, hooked up forscan and its only showing 11v.
in the DTC i have a pcm error code
p1632:09 2f
Code: P1632 - Smart Alternator Faults Sensor / Circuit
Additional Fault Symptom (:09):
- Component Failures
Status (-2F):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Powertrain Control Module
Freeze Frame #1:
-EVENT_TIME: 345048079 s (Sat Apr 20 11:47:07 2024) - Event time
-TOTAL_DISTANCE: 168305 miles - Total Distance
-MODULE_VOLTAGE: 11.0 V - Control Module Voltage
and
p1632:49 2f
Additional Fault Symptom (:49): - Internal Electronic Failure
Status (-2F):
Freeze Frame #1:
in the pid data the the generator/alternator voltage is reading 14.9v
