Hi everyone,
I have a 2009 Ford Transit with two batteries that recently stopped charging. I installed a new alternator and new batteries as they were old and the original. However, the battery still isn't charging.
I've checked all the fuses and swapped around the relays. I also replaced the alternator wire that goes to the starter and the cable from the starter motor to the engine fuse box, as they were slightly corroded, but still no luck.
Interestingly, when I rev the engine, the voltage slightly drops instead of increasing. Has anyone experienced something similar or have any suggestions on what to try next? I'm running out of ideas and could really use some help.
Thanks in advance!
