fuse layout
fuse layout
Postby taylex » Fri Jan 25, 2008 3:17 pm
can any one tell me where i can find a layout for both fuse boxes??
my indicators are not working on my 53 reg transit jumbo, i cant see any blow fuses but do not know exactly which to check.
taylex
Re: fuse layout
Postby BigNeil » Fri Jan 25, 2008 3:21 pm
have you not got a manual in the glove box ?
BigNeil
Re: fuse layout
Postby taylex » Fri Jan 25, 2008 4:33 pm
no i didnt get a manual with it. its an ex parcel line van.
i have now found that the fuse had been left out as it keeps blowing
i'm tracing back the wires to find whats be short circuted.
taylex
Re: fuse layout
Postby BigNeil » Fri Jan 25, 2008 4:35 pm
spmepne here will tell you when they start coming in from work
BigNeil
Re: fuse layout
Postby Altransit » Fri Jan 25, 2008 5:29 pm
:idea: Disconnect the feed wires into the light clusters, and try another fuse.
If the fuse still blows, then it's a wiring fault, if it doesn't, then one of the bulbs or holder is to blame. If it is a wiring fault, check that no one has put a screw through a wire, in the load area :shock:
Just a few ideas to start with :wink:
Re: fuse layout
Postby taylex » Sun Jan 27, 2008 6:23 pm
Cheers for your help, I sorted it in the end, i also found a tracker!!
Looks like who ever decomissioned the vehicle from parcel line cut the wries to the tracker and joined them to the radio to make the radio work. I have new rewired and have indicators and radio.
taylex
Users browsing this forum: Google [Bot], gt_addict
