57 Plate transit wingmirror removal
Postby JCallan » Tue Nov 04, 2008 12:52 pm
Hi guys first post so go easy!!! cannot for the life of me work out how to remove the wingmirror off a 57 plate transit minibus, it has two colts at the bottom and some blanking piece at the top, anybody know? many thanks in advance
JCallan
Re: 57 Plate transit wingmirror removal
Postby Frag » Tue Nov 04, 2008 1:10 pm
The bolt that looks like a blanking piece is a shear bolt,head snaps off when tightened.
Stops people pinching your mirrors easily :o
If your mirrors u/s destroy the plastic around this bolt & then using a centre punch/chisel tap it loose & screw it out.
Never removed an undamaged mirror but i guess you`d have to drill bolt then use a stud extractor or something..............
Frag
Ford Technician
