DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby jonb1985 » Tue Jun 12, 2018 9:33 pm
Chuggy wrote:
jonb1985 wrote:Hello, I'm new here, please can I have the details for my transit mk3 based camper van, reg H141KBL?
Many thanks!
Jon
We are sorry, but no information could be found for the VIN/Registration number you entered - H141KBL
What is your VIN number Jon?
HI, thanks for looking for me - VIN number is SFACXXBDVCLB22724
Specifically I'm trying to understand which gearbox I have (Possibly the MT75?) as I need to top up the oil, and know you have to be careful what fluid you put in depending on which gearbox it is
jonb1985
Postby Chug » Wed Jun 13, 2018 9:11 am
Transit 86
VIN Number: SFACXXBDVCLB22724
Primary Features
Build Date: 29.10.1990
Vehicle Line: Transit 86
Interior Fabric: Interior Environment
I'm afraid this is all the info available on Etis, but is it petrol or diesel?
petrol will be type 9 G/box https://www.classicfordmag.co.uk/wp-con ... -guide.pdf
diesel will be MT75 G/box http://www.super7thheaven.co.uk/compone ... 5-gearbox/
Chug
Postby jonb1985 » Wed Jun 13, 2018 12:10 pm
Chuggy wrote:Transit 86
Primary Features
Thanks a lot Chuggy, it's petrol, but on the gear lever, the reverse gear is located beneath gear 5, elsewhere on this forum people have said that it's different for a type 9? So I'm a little confused. On the VIN plate under Trans it says "C8", if that means anything?
I guess a good way to check would to get under there and take a look, from the links you've sent across it appears that the casings look quite different from one another (e.g. It appears that there are lots of ribs on the Mt75 casing but not on the type 9)
jonb1985
Postby Chug » Wed Jun 13, 2018 9:39 pm
Yeah sorry that was a bit of a generalisation, the MT75 was also fitted to the pinto petrol engine using an adapter plate.
If you have C8 in box 2 on the Vin plate then it should be - MT75 5 Speed Close ratio (3.89)
Chug
Postby BradM » Sat Jun 16, 2018 2:28 am
Hi there would like some info especially diff ratio on my van 2007 transit vin WFOXXXTTFX6A20739
Thanks bradM
BradM
Postby lewgiboy » Sun Jun 17, 2018 11:00 pm
Good evening all...
Got another tourney yesterday ls56 ogr...
Can anyone help...
Many thanks
lewgiboy
Postby twin--turbo » Wed Jun 20, 2018 5:48 pm
ST56 RJF
TT
twin--turbo
Postby Chug » Thu Jun 21, 2018 9:01 pm
BradM wrote:Hi there would like some info especially diff ratio on my van 2007 transit vin WFOXXXTTFX6A20739
Thanks bradM
Transit 2006-2014, 2.3L Duratec-HE (145PS) - MI4, Frozen White
VIN Number: WF0XXXTTFX6A20739
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 14.11.2006
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 1.7-350L Series
Engine: 2.3L Duratec-HE (145PS) - MI4
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 5.11
Emission: Stage IV Emissions
Air Conditioning: Manual Air Conditioning
Territory: (+)"AUS"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With Medium Roof
With Rear Mudflaps
High Door Height
Otosan (Turkey) Plant Build
Complete Vehicle
Less Marketing Flex Prep Pack
Less SVO Application/Label
Less Trim Pack
With Power Equipment Group
Marketing Level 3
Less Smoke Compliance Label
European Environmental Label
With Power Front Windows
With All Light Tinted Glass
Less 2nd Row RH Side Window
With Fixed Rear Window
With Heated Rear Window
With Complete Rear Hardboard Trim
With Bright Air Vent Knob
With Load Space Tie Down Loop
With Cargo Stowage Rail (Mid)
Less Rear Step
Large Head/Short Arm Mirror
Seat Pack 22
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Rear Seat Armrest Packs
Less Trailer Towing Attachments
With Front Towing Hook
With Door Dead Locks
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Rear Plastic Grey Bumper-With Step
Less Rear Seat Belts
Less Passenger Air Bag
Less Float Mounting
With Spare Tyre Security Package
Less Diesel Fuel Cooler
Cold Start Up To -20%c
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Less Transfer Case
With Sngle.L/B Dvr/Dual L/B Pass.St
Less A/C Unit - Roof Mounted
With Recirculating Heater
Fuel Water Separator Less Sensor
For Unleaded Fuel
Less Auxiliary Heater
With KMH Speedometer
With Perimeter Anti-Theft
Extra Heavy Duty Battery
With Radio Pre-Equipment Pack 1
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 2
Less Voice Activated Modules
Less Column Stalk Radio Controls
With Smokers Package
With Power Point Plug - Rear
With High Mounted Stop Lamp
Less Battery Cut Off Relay
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
Chug
Postby Chug » Thu Jun 21, 2018 9:03 pm
lewgiboy wrote:Good evening all...
Can anyone help...
Many thanks
Transit 2006-2014, 2.2L Duratorq-TDCi (110PS) - Puma, Moondust Silver (Metallic)
VIN Number: WF0BXXBDFB6A67684
Registration Number: LS56OGR
First Registration Date: 23.02.2007
Registration Country: GB
Primary Features
Build Date: 24.01.2007
Cab Style: Bus (M1 LRF)
Series: 280S Series
Engine: 2.2L Duratorq-TDCi (110PS) - Puma
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Territory: (+)"GB"
Paint: Moondust Silver (Metallic)
Interior Fabric: Kado (G-C)
Minor Features
With Low Roof
With Dual Side Load Doors
Less Bulkhead
With Liftgate Rear Loading Door
With Cold Climate Liftgate
Southampton Plant Built
Complete Vehicle
Incomplete - Ship To VFS
Less Trim Pack
Marketing Level 3
With Visibility Pack
With RH 2nd Row Sliding Window
With LH 2nd Row Sliding Window
With RH 3rd Row Fixed Window
With LH 3rd Row Fixed Window
With Heated Windscreen
With Premium PVC Trim Board
With Interior Cladding Surfaces
With Carpet Floor Covering
With Full Headlining - Moulded
Less Rear Window Protector
Less Rear View Mirror
With Passenger Seat Valance
Less 6th Row Seating
2nd Row Triple Midi Fold Seat
With 3rd Row Folding Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
With Driver 8 Way Mnl.Seat Adjuster
Rear Seat Armrest Pack 1
Fleet Key
With Trans Linked Rr Washer/Wiper
Rain Sensor - Fr Windscreen Wiper
Front Bumper Body Coloured Plastic
With Standard Rear Seat Belts
With Passenger Air Bag
With Adjustable 'D' Ring Pass Seat
Less Float Mounting
With Single Rear Wheels
With Full Wheel Cover
With Standard Tread - Any Vendor
Less Rear Stabilizer Bar
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
With MPH/KMH Speedometer
With Trip Computer
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
With Radio Pre-Equipment Pack 2
High CDX6+AM/FM Radio W/Diversity
Ice Feature Pack 9
Less Telephone Preparation Pack
With Column Stalk Radio Controls
With Front Fog Lamps
With Front Headlamp Levelling
With Automatic Headlamp On/Off
With Instrument Panel Dimmer Switch
Chug
Postby Chug » Thu Jun 21, 2018 9:06 pm
twin--turbo wrote:ST56 RJF
TT
We are sorry, but no information could be found for the VIN/Registration number you entered - ST56RJF
Give us the Vin number to try.
Chug
Postby riauba » Fri Jun 22, 2018 4:08 pm
LD62VWR
please
riauba
Postby twin--turbo » Fri Jun 22, 2018 6:36 pm
Sorry ST56 RFJ
Cheers
TT
TT
twin--turbo
Postby landymike » Sat Jun 23, 2018 7:26 pm
Hi, would you be kind enough to perform a search on my newly acquired transit, VN 02 NXY.
Thank you.
Everything is literal to me. If you do not like it that is your problem.
I have no time for idiocy or rudeness.
landymike
Postby Chug » Sat Jun 23, 2018 11:14 pm
twin--turbo wrote:Sorry ST56 RFJ
Cheers
TT
TT
That's better!
Transit 2006-2014, 2.4L Duratorq-TDCi (100PS) - Puma, Frozen White
VIN Number: WF0XXXTTFX6A08360
Registration Number: ST56RFJ
First Registration Date: 12.01.2007
Primary Features
Build Date: 01.11.2006
Engine: 2.4L Duratorq-TDCi (100PS) - Puma
Drive: RHD RWD
Axle Ratio: 5.11
Territory: (+)"GB"
Paint: Frozen White
Minor Features
With Medium Roof
High Door Height
Less Bulkhead
With Full Partition - Steel
Complete Vehicle
Less Trim Pack
Less Power Equipment Group
Marketing Level 3
With Manual Front Windows
With Clear/Light Tinted Glass
With Rear Blanking Panel
Less Heated Rear Window
Less Rear Compartment Trim Panel
With Black Air Vent Knob
Less Front Roof Grab Handle
Seat Pack 22
Fleet Key
Less Rear Window Wiper/Washer
Less Float Mounting
Less Engine RPM Control
Less Transfer Case
Ice Feature Pack 2
Chug
Postby Chug » Sat Jun 23, 2018 11:15 pm
landymike wrote:Hi, would you be kind enough to perform a search on my newly acquired transit, VN 02 NXY.
Thank you.
Transit 2000-2006, 2.4L Duratorq DI (90PS), Saffron Yellow (XSC1517)
VIN Number: WF0LXXBDFL2T30091
Registration Number: VN02NXY
First Registration Date: 27.05.2002
Primary Features
Build Date: 03.04.2002
Vehicle Line: Transit 2000-2006
Series: 330S Series
Engine: 2.4L Duratorq DI (90PS)
Drive: RHD RWD
Axle Ratio: 4.63
Emission: Light Duty Truck Stage III
Territory: (+)"GB"
Paint: Saffron Yellow (XSC1517)
Interior Colour: Dark Graphite
Interior Fabric: Stylize (-I-C)
Chug
