Steve192 wrote:Hi could someone please get my spec from my reg below?
Much appricaiated
NL62 SVJ
Transit 2006-2014, 2.2L CR TC I4 DSL 100PS, Frozen White
VIN Number: WF0XXXBDFXCL46277
Registration Number: NL62SVJ
First Registration Date: 01.10.2012
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 10.09.2012
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 280S Series
Engine: 2.2L CR TC I4 DSL 100PS
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.36/3.05
Emission: Stage V LDT3 Emissions
Air Conditioning:
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
• With Medium Roof
• Less Roof Line Conversion
• With Rear Mudflaps
• Less Front Susp'n Skid Plates
• Less Interior Pack
• Less Front Mudflaps
• Narrow Door Width
• Low Door Height
• With Kerbside Side Load Doors
• With Diesel Particulate Filter
• Less Back Panel Bulkhead Grille
• With Full Partition
• With Hinged Rear Loading Doors
• With 180° Cargo Door Check Arms
• With Unrestricted Side Load Dr Opng
• Less Folding Step - Side Door Load
• Less Rear Door Catch
• Less Liftgate
• Less Second Unit Body
• Less Mesh Headboard 2nd Unit
• Less Tailboard Support Straps
• Less Auxiliary I/P Console
• With Standard GVM Rating
• Southampton Plant Built
• Less Special Equipment Package
• Less Marketing Flex Prep Pack
• Less Sales Badge
• Less SVO Application/Label
• Less Trim Pack
• Less Special Value Packages
• Less Power Equipment Group
• Marketing Level 3
• Less Visibility Package
• Less Dress Up RSO
• Less Paint Package
• Less Utility Package
• Less Certification Label
• Less Fire Extinguisher Fixings
• With Tool Kit
• Less Tyre Repair Service Kit
• With Power Front Windows
• With All Light Tinted Glass
• Less Front Side Door Security Glass
• Less 2nd Row RH Side Window
• Less 2nd Row LH Side Window
• Less 3rd Row RH Side Window
• Less 3rd Row LH Side Window
• With Rear Blanking Panel
• Less Rear Side/Back Security Glass
• With Heated Windscreen
• Less Heated Rear Window
• Less Overhead Console
• With Header Mounted Package Tray
• Less Rear Compartment Trim Panel
• Less Inter Cladding Surfaces
• Less Front Floor Mats
• Flr Cvr-Rubber Ins-Extended
• With Bright Air Vent Knob
• With Partial Headlining - Moulded
• With Door Map Pocket
• Less Interior Grab Handle Side Door
• Less Front Roof Grab Handle
• Less A Pillar Assist Handle
• Less 'B' Pillar Assist Handle
• With Load Space Tie Down Loop
• Less Load Floor Covering
• Less Load Area Protection Kit
• With Cargo Stowage Rail (Mid)
• Less Load Compartment Tie Down
• Drivers Door Trim - Level 2
• Passenger Door Trim - Level 1
• Less Running Boards
• Less Roof Rack
• Less Exterior Body Mouldings
• Less Rear Window Protector
• Less Rear Step
• Less Rear View Mirror
• Large Head/Short Arm Mirror
• Manual Dual Mirror-Manual Fold Back
• Less Seat Construction
• Less Rear Underseat Stowage Bin
• With Drivers Seat Fixed Armrest
• Less Passenger Seat Armrests
• Less Rear Seat Recliner
• Less Passenger Seat Valance
• Less Seat/Airbag Pack
• Less 6th Row Seating
• Less Temp Control Driver Seat
• Less Temp Control Passengers Seat
• Less 2nd Row Rear Seat
• Less 3rd Row Rear Seat
• Less 4th Row Rear Seat
• Less Fifth Row Seating
• Less Rear Seats Fixings
• Less 2nd Row Reversed Triple Seat
• With Driver 6 Way Mnl.Seat Adjuster
• Less Adjustable Passenger Seat
• Less Removable 2nd Row Seat
• Less Rear Seat Armrest Packs
• Less Rear Seat Packs
• Less Trailer Towing Attachments
• Less Trailer Coupling
• Less Front Towing Hook
• Rear Axle Alternative A
• Fleet Key
• With Door Auto Relocking - Enabled
• Less Zonal Opposite Door Relocking
• Less Configurable Unlocking
• With Door Dead Locks
• With Power Lock Group
• Two Step Door Unlock System
• Less Side/Rr Door Security Lockset
• With Door Entry Remote Control Unit
• Less Rear Window Wiper/Washer
• Less Rain Sensor - Front W/Wiper
• Less Sun Roof
• Less Rear Sunroof
• Self Colour Rear Bumper End Caps
• Mid Grey Front Bumper
• With Grey Plastic Rear Bumper
• Less Rear Bumper Under Run
• Less Bumper Underrun - Front
• Less Rear Seat Belts
• With Driver Air Bag
• Less Passenger Air Bag
• Tyre Carrier Drop-Dr Open
• Less Side Underrun Rails
• Less Float Mounting
• With Steel Spare Wheel
• With Silver Wheel Finish
• With Spare Tyre Security Package
• With Single Rear Wheels
• 5 1/2J x 15 Steel Wheel
• 195/70R 15C LI 104/102 BSW
• With Wheel Hub Cap
• Non Locking Lug Nuts
• Diesel Fuel Cooler
• Less Engine RPM Control
• Cold Start Up To -20%c
• Standard Electric Starter Motor
• Stage V LDT3 Emissions
• Dual Mass Flywheel
• With Standard Attitude/Ride Height
• With Standard Duty Front Suspension
• Front Axle Rating-Normal
• With Front Stabilizer Bar
• With Standard Duty Rr Leaf Springs
• Less Rear Auxiliary Springs
• With Standard Rear Suspension
• Less Rear Stabilizer Bar
• With Down Turned Exhaust Exit
• With Tunnel Mounted Parking Brake
• Power 4-Wheel Disc Vacuum Boost
• 4 Wheel Anti-Lock Braking System
• Electronic Stability Brk Ctrl (ESP)
• Less Transfer Case
• Less Skid Plates
• With Sngle.L/B Dvr/Dual L/B Pass.St
• Less Rear Seat Climate Control
• Less Heater
• With 80 Litre Fuel Tank
• Less Fuel Water Separator
• With Diesel Fuel Capability
• With Power Steering(Variable Ratio)
• Basic Type Steering Wheel
• Less Auxiliary Heater
• Less Heater/Air Con Prep Pack
• Less Auxiliary Hot Water Heater
• Less Rear Compartment Heating
• With MPH/KMH Speedometer
• Less Tachograph
• Less Tripminder Assy
• With Tachometer
• Less Navigation Disk
• Less Navigation Data
• Less Seat Belt Warning Light
• Less Reverse Proximity Sensor
• Less Anti-Theft Alarm
• Less Engine Immobiliser
• Standard Duty Battery
• Less Deep-Discharge Batteries
• Standard Duty Alternator
• Less Radio Pre-Equipment Pack
• Less Bluetooth
• Roof Mounted Radio Antenna
• ICE-Low Level CD + AM/FM Radio
• Ice Feature Pack 5
• Less Speaker
• Less Telephone
• Less Telephone Preparation Pack
• Less Microphone
• Less Voice Activated Modules
• With Column Stalk Radio Controls
• Electrical Outlet
• Less Smokers Package
• Less Power Point Plug - Rear
• Less Camera
• Less Optional Equipment Pack
• Less Wheel Pack
• Less Aero Pack
• With Daytime Running Lamps
• Less Front Fog Lamps
• Less Roof Marker/Clearance Light
• Less Footwell Lights
• Less Interior Courtesy Lamp
• Less Load Compartment Lamp
• Less Side Marker Lamps
• With High Mounted Stop Lamp
• Less Roof Mounted Turn Signals
• Less Rear Marker Lamps
• With Front Headlamp Levelling
• Less Headlamp Control
• Less Instrument Panel Dimmer Switch
• Less Wiring Harness
• Less Roof Flasher Wiring
• Less Auxiliary Fuse Panel
©Copyright, Ford Motor Company 1994 - 2017 | Privacy Policy
Action took ms. on eccvas1900j-eccvas1900j
