Flying Scotsman wrote:Hi would it possible to find out any info for a van that i am looking to buy
Ford Tansit SW11ERO
Cheers
Outstanding Field Service Actions: No Campaign Message(s) found
Transit 2006-, 2.2L Duratorq TDCi (115PS) - Puma, Ink Blue (Metallic)
VIN Number: WF05XXBDF5BL10254
Registration Number: SW11ERO
First Registration Date: 10.06.2011
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 01.06.2011
Vehicle Line: Transit 2006-
Cab Style: Double Cab In Van
Series: 260S Series
Engine: 2.2L Duratorq TDCi (115PS) - Puma
Transmission: 6-Speed Manual Transaxle - VMT6
Drive: RHD FWD
Axle Ratio: 4.36/3.05
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Ink Blue (Metallic)
Interior Colour: Lichen
Interior Fabric: Tomy (B-C)
Minor Features
With Low Roof
Less Roof Line Conversion
With Rear Mudflaps
Less Front Susp'n Skid Plates
Less Interior Pack
Less Front Mudflaps
Narrow Door Width
Low Door Height
With Kerbside Side Load Doors
Less Diesel Particulate Filter
Less Back Panel Bulkhead Grille
Less Brake System-Regenerative
Less Bulkhead
With 180° Cargo Door Check Arms
With Unrestricted Side Load Dr Opng
Less Folding Step - Side Door Load
Less Rear Door Catch
Less Liftgate
Less Second Unit Body
Less Mesh Headboard 2nd Unit
Less Tailboard Support Straps
Less Auxiliary I/P Console
With Standard GVM Rating
Southampton Plant Built
Less Special Equipment Package
Less Marketing Flex Prep Pack
Trend Sales Badge
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 4
With Visibility Pack High
Less Dress Up RSO
Less Utility Package
Less Certification Label
Less Fire Extinguisher Fixings
With Tool Kit
Less Tyre Repair Service Kit
With Power Front Windows
With All Light Tinted Glass
Less Front Side Door Security Glass
With RH 2nd Row Fixed Window
With LH 2nd Row Fixed Window
Less 3rd Row RH Side Window
Less 3rd Row LH Side Window
With Rear Blanking Panel
Less Rear Side/Back Security Glass
With Heated Windscreen
Less Heated Rear Window
Less Overhead Console
Less Header Mounted Package Tray
With Complete Rear Hardboard Trim
Less Inter Cladding Surfaces
Less Front Floor Mats
With Rubber Floor Covering
With Bright Air Vent Knob
With Full Headlining - Moulded
Less Door Map Pocket
Less Interior Grab Handle Side Door
Less Front Roof Grab Handle
Less A Pillar Assist Handle
Less 'B' Pillar Assist Handle
With Load Space Tie Down Loop
Less Load Floor Covering
Less Load Area Protection Kit
Less Cargo Stowage Rack/Rail
Less Load Compartment Tie Down
Drivers Door Trim - Level 2
Passenger Door Trim - Level 2
Less Running Boards
Less Roof Rack
With Narrow Body Moulding
Less Rear Window Protector
Less Rear Step
Less Rear View Mirror
Large Head/Short Arm Mirror
Dual Power Heated Exterior Mirrors
Less Seat Construction
Less Rear Underseat Stowage Bin
With Drivers Seat Fixed Armrest
With Passenger Seat Fixed Armrests
Less Rear Seat Recliner
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
With 2nd Row Bench Seat - 3 Passngr
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
Rear Seat Fixings-2nd Row Narrow
Less 2nd Row Reversed Triple Seat
With Driver 6 Way Mnl.Seat Adjuster
With Pass 4 Way Manual Seat Adjust
Less Removable 2nd Row Seat
Less Rear Seat Armrest Packs
Rear Seat Pack 2
Less Trailer Towing Attachments
Less Trailer Coupling
Less Front Towing Hook
Rear Axle Alternative A
Less Fleet Key
With Door Auto Relocking - Enabled
Less Configurable Unlocking
With Door Dead Locks
With Power Lock Group
Two Step Door Unlock System
Less Side/Rr Door Security Lockset
Remote Control Door Entry - 2 Fob
Less Rear Window Wiper/Washer
Rain Sensor - Fr Windscreen Wiper
Less Sun Roof
Less Rear Sunroof
Front Bumper Body Coloured Plastic
Less Rear Bumper Under Run
Less Bumper Underrun - Front
With Standard Rear Seat Belts
With Driver Air Bag
Less Passenger Air Bag
Tyre Carrier Drop-Dr Open
Less Side Underrun Rails
Less Float Mounting
With Steel Spare Wheel
With Silver Wheel Finish
With Spare Tyre Security Package
With Single Rear Wheels
5 1/2J x 15 Steel Wheel
195/70R 15C LI 100/98 BSW
With Full Wheel Cover
Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Standard Electric Starter Motor
Dual Mass Flywheel
With Standard Attitude/Ride Height
With Standard Duty Front Suspension
Front Axle Rating-Normal
With Front Stabilizer Bar
With Standard Duty Rr Leaf Springs
Less Rear Auxiliary Springs
With Standard Rear Suspension
Less Rear Stabilizer Bar
With Down Turned Exhaust Exit
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
Less Skid Plates
Standard Front Seat
Less Rear Seat Climate Control
Less Heater
With 80 Litre Fuel Tank
Less Fuel Water Separator
With Diesel Fuel Capability
With Power Steering(Variable Ratio)
Leather Strg Whl-Air/Bag+Crse Cont
Less Auxiliary Heater
Less Heater/Air Con Prep Pack
Less Auxiliary Hot Water Heater
Less Rear Compartment Heating
With MPH/KMH Speedometer
With Trip Computer
With Tachometer
Less Navigation Disk
Less Navigation Data
Less Seat Belt Warning Light
Less Reverse Proximity Sensor
Less Anti-Theft Alarm
Less Engine Immobiliser
Standard Duty Battery
Less Deep-Discharge Batteries
Standard Duty Alternator
Less Radio Pre-Equipment Pack
BT/VC Phone Interface Only
Roof Mounted Radio Antenna
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 5
Less Telephone
Less Telephone Preparation Pack
Less Microphone
Voice Activated Module - British
With Col Stalk Rado Contr W/PTT-BTN
Electrical Outlet
Less Smokers Package
Less Power Point Plug - Rear
Less Camera
Less Optional Equipment Pack
Less Wheel Pack
Less Aero Pack
Less Daytime Running Lamps
With Front Fog Lamps
Less Roof Marker/Clearance Light
With Footwell Lights
Less Interior Courtesy Lamp
Less Load Compartment Lamp
Less Side Marker Lamps
With High Mounted Stop Lamp
Less Roof Mounted Turn Signals
Less Rear Marker Lamps
With Manual Headlamp Levelling
With Automatic Headlamp On/Off
With Instrument Panel Dimmer Switch
Less Wiring Harness
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
©Copyright, Ford Motor Company 1994 - 2015 | Privacy Policy
