ColinK wrote:MK7 user wrote:ColinK wrote:Hello chaps,
Is there any chance of my vans spec. Just going to replace the diff and it would be great to know the current ratio and other sexy bits.
Thanks for your help, Colin.
Reg. AF56VHT.
We are sorry, but no information could be found for the Registration number you entered -
AF56VHTTry the VIN number.
Hello thanks for trying. The VIN is. WF0XXXTTFX6J78182
Cheers. Colin
The van was probably supplied by the dealer without being registered - no reg. in the Etis print.
Outstanding Field Service Actions: No Campaign Message(s) foundTransit 2006-, 2.4L Duratorq (85kW/115PS), Frozen White
VIN Number: WF0XXXTTFX6J78182
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary FeaturesBuild Date: 20.05.2006
Vehicle Line: Transit 2006-
Cab Style: Regular Cargo Van
Series: 1.7-350L Series
Engine: 2.4L Duratorq (85kW/115PS)
Transmission: 6 Speed Manual Transmission-MT82
Drive: RHD RWD
Axle Ratio: 3.73
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
[b]Minor Features[/b]
With High Roof
High Door Height
With Full Partition - Steel
Otosan (Turkey) Plant Build
Less Marketing Flex Prep Pack
Less SVO Application/Label
Less Trim Pack
Less Power Equipment Group
Marketing Level 3
European Environmental Label
With Manual Front Windows
With Clear/Light Tinted Glass
Less 2nd Row RH Side Window
With Rear Blanking Panel
Less Heated Rear Window
Less Rear Compartment Trim Panel
With Front Roof Grab Handle
With Load Space Tie Down Loop
Less Rear View Mirror
Large Head/Short Arm Mirror
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Rear Seat Armrest Packs
With Front Towing Hook
With Door Dead Locks
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rear Seat Belts
Less Passenger Air Bag
Less Float Mounting
With Spare Tyre Security Package
Less Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
With Brake Only Traction Control
Less Transfer Case
With Sngle.L/B Dvr/Dual L/B Pass.St
Less A/C Unit - Roof Mounted
With Recirculating Heater
Fuel Water Separator Less Sensor
Less Auxiliary Heater
With MPH/KMH Speedometer
Less Reverse Proximity Sensor
Extra Heavy Duty Battery
With Radio Pre-Equipment Pack 1
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 2
Less Column Stalk Radio Controls
Less Smokers Package
Less Optional Equipment Pack
With High Mounted Stop Lamp
With Manual Headlamp Levelling
Less Battery Cut Off Relay
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
©Copyright, Ford Motor Company 1994 - 2015 | Privacy Policy
