DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Re: DETAILS OF YOUR VAN? off Ford ETIS - ask here!!
Postby Chug » Fri Jun 01, 2018 9:17 am
Fezzer wrote:Hi recently purchased my Van can I have Details for Reg No Ys07uxy please
Transit 2006-2014, 2.4L Duratorq-TDCi (100PS) - Puma, Frozen White
VIN Number: WF0XXXTTFX7D13351
Registration Number: YS07UXY
First Registration Date: 27.07.2007
Registration Country: GB
Type Approval Number (TAN): E1*2007/46*0248 / E1*2007/46*0264
Primary Features
Build Date: 08.03.2007
Vehicle Line: Transit 2006-2014
Cab Style: Regular Cargo Van
Series: 1.7-350L Series
Engine: 2.4L Duratorq-TDCi (100PS) - Puma
Transmission: 5-Speed Manual Transmission - MT75
Drive: RHD RWD
Axle Ratio: 4.78
Emission: Stage IV Emissions
Territory: (+)"GB"
Paint: Frozen White
Interior Colour: Lichen
Interior Fabric: Tomy (G-C)
Minor Features
With High Roof
High Door Height
With Full Partition - Steel
Otosan (Turkey) Plant Build
Complete Vehicle
Less Marketing Flex Prep Pack
Less SVO Application/Label
Less Trim Pack
Less Special Value Packages
Less Power Equipment Group
Marketing Level 3
European Environmental Label
With Manual Front Windows
With Clear/Light Tinted Glass
Less 2nd Row RH Side Window
With Rear Blanking Panel
Less Heated Rear Window
Less Rear Compartment Trim Panel
With Black Air Vent Knob
With Partial Headlining - Moulded
With Load Space Tie Down Loop
Less Rear Window Protector
With Rear Step - Centre
Less Rear View Mirror
Large Head/Short Arm Mirror
Seat Pack 22
With Drivers Seat Fixed Armrest
Less Passenger Seat Armrests
Less Passenger Seat Valance
Less Seat/Airbag Pack
Less 6th Row Seating
Less Temp Control Driver Seat
Less Temp Control Passengers Seat
Less 2nd Row Rear Seat
Less 3rd Row Rear Seat
Less 4th Row Rear Seat
Less Fifth Row Seating
With Driver 6 Way Mnl.Seat Adjuster
Less Adjustable Passenger Seat
Less Rear Seat Armrest Packs
Less Rear Seat Packs
Less Trailer Towing Attachments
With Front Towing Hook
With Door Dead Locks
Less Side/Rr Door Security Lockset
With Door Entry Remote Control Unit
Less Rear Window Wiper/Washer
Less Rear Seat Belts
Less Passenger Air Bag
Less Float Mounting
With Spare Tyre Security Package
With Single Rear Wheels
With Standard Tread - Any Vendor
Less Diesel Fuel Cooler
Less Engine RPM Control
Cold Start Up To -20%c
Less Rear Stabilizer Bar
With Tunnel Mounted Parking Brake
Power 4-Wheel Disc Vacuum Boost
4 Wheel Anti-Lock Braking System
Electronic Stability Brk Ctrl (ESP)
Less Transfer Case
With Sngle.L/B Dvr/Dual L/B Pass.St
Less A/C Unit - Roof Mounted
With Recirculating Heater
Fuel Water Separator Less Sensor
Less Auxiliary Heater
With MPH/KMH Speedometer
Extra Heavy Duty Battery
With Radio Pre-Equipment Pack 1
ICE-Low Level CD + AM/FM Radio
Ice Feature Pack 2
Less Voice Activated Modules
Less Column Stalk Radio Controls
Less Smokers Package
With High Mounted Stop Lamp
Less Battery Cut Off Relay
Less Roof Flasher Wiring
Less Auxiliary Fuse Panel
Chug
Postby Midgeland » Fri Jun 01, 2018 10:36 am
ETIS please forPJ08 WYM
Midgeland
Postby Fezzer » Fri Jun 01, 2018 6:51 pm
Cheers Chuggy!
Fezzer
Postby PIJ » Sun Jun 03, 2018 10:02 pm
Details of SD06KMF
PIJ
Postby ozzy69 » Mon Jun 04, 2018 12:27 pm
Hi can i get my etis for both sc56vyb and nj06nnr the first one is my doner mk7 for my mk6
ozzy69
Postby Louey » Mon Jun 04, 2018 12:50 pm
Since my engine is knackered I think it's a good time to double check the engine spec
Reg is BN03KKZ
Louey
Louey
Postby loot » Mon Jun 04, 2018 2:35 pm
Louey wrote:Since my engine is knackered I think it's a good time to double check the engine spec
Reg is BN03KKZ
Transit 2000-2006, 2.4L Duratorq DI (90PS), Diamond White 73
VIN Number: WF0LXXGBFL3K74666
Ids map here
loot
Postby trans-it-mad » Mon Jun 04, 2018 8:44 pm
Chuggy wrote:
trans-it-mad wrote:
Chuggy wrote:Don't know why no build date etc comes up and your other reg number gives an error.
"We are sorry, but no information could be found for the VIN/Registration number you entered - PN52OGK"
Have you got the VIN number?
so ne detail are coming up from my registration number......it is that suspicious :?: :?: ?
the VIN Number: WF0LXXGBFL2R80143 that I give it already to you and all the detail come up but no reg number etc.....
now I'm getting worry here....
any clue of the mystery?
Quite a few searches don't work with reg number but Searching on google brings up
FORD TRANSIT 350 2.3 LWB, 5 Doors Panel Van Manual Petrol/LPG, Spare Key(s), N/S Loading Door, Stereo,
try the MOT history https://www.check-mot.service.gov.uk/
thanks a million for all the checks you run.... will try the link you send me....ta!
MK6 LWB RWD BI-FUEL broom broom :lol:
trans-it-mad
Postby Chug » Tue Jun 05, 2018 9:23 am
Midgeland wrote:ETIS please forPJ08 WYM
VIN Number: WF0FXXTTFF8B83047
Registration Number: PJ08WYM
First Registration Date: 13.05.2008
Primary Features
Build Date: 24.01.2008
Cab Style: Single Cab (2 Door)
Series: 350E Series
Drive: RHD RWD
Axle Ratio: 5.11
Territory: (+)"GB"
Paint: Frozen White
Minor Features
Less Side Load Doors
Less Diesel Particulate Filter
Less Bulkhead
Less Special Equipment Package
Marketing Level 3
With Fixed Rear Window
Flr Cvr-Rubber Ins-Extended
Large Head/Long Arm Mirror
Seat Pack 22
Fleet Key
With Double Rear Wheels
5 X 16" Steel Wheel
Less Wheel Covers
Less MPH Engine Governor
Front Axle Rating-Normal
Less Anti-Theft Alarm
Less Deep-Discharge Batteries
Ice Feature Pack 2
Less Wheel Pack
Less Daytime Running Lamps
Chug
Postby Chug » Tue Jun 05, 2018 9:25 am
PIJ wrote:Details of SD06KMF
Transit 2000-2006, 2.0L Duratorq DI(100PS), Diamond White 73
VIN Number: WF0TXXBDFT6S14543
Registration Number: SD06KMF
First Registration Date: 19.04.2006
Primary Features
Build Date: 03.03.2006
Vehicle Line: Transit 2000-2006
Cab Style: Bus (M1 LRF)
Series: 280S Series
Engine: 2.0L Duratorq DI(100PS)
Transmission: 5-Speed Manual Transaxle - VXT75
Drive: RHD FWD
Axle Ratio: 4.23
Emission: Light Duty Truck Stage III
Air Conditioning: Manual Air Conditioning
Territory: (+)"GB"
Paint: Diamond White 73
Interior Colour: Dark Graphite
Interior Fabric: GC Flayers
Minor Features
With Low Roof
With Front Mudflaps
RH Sliding Side Cargo Door - Low
LH Sliding Side Cargo Door - Low
With Liftgate Rear Loading Door
With Standard Liftgate
Southampton Plant Built
Marketing Level 3
With Light Tint/Dark Tinted Glass
With RH 2nd Row Sliding Window
With LH 2nd Row Sliding Window
With RH 3rd Row Fixed Window
With LH 3rd Row Fixed Window
With Heated Rear Window
Less Header Mounted Package Tray
With Premium PVC Trim Board
With Interior Cladding Surfaces
With Carpet Floor Covering
With Full Headlining - Moulded
With Roof Height Feature Pack 2
With Sunvisor Mirror - Passenger
With Front Roof Grab Handle
Drivers Door Trim - Level 2
Passenger Lrg Head/Short Arm Mirror
With Passenger Seat Valance
2nd Row Triple Midi Fold Seat
With 3rd Row Folding Seat
With 2nd Row Folding Armrests
With 3rd Row Folding Armrests
With Driver 8 Way Mnl.Seat Adjuster
Less Removable 2nd Row Seat
Rear Seat Armrest Pack 1
Rear Seat Pack 7
Fleet Key
With Int. Rear Window Wiper/Washer
With Driver Air Bag
With Passenger Air Bag
With Adjustable 'D' Ring Pass Seat
5 1/2J x 15 Steel Wheel
195/70R 15C LI 104/102 BSW
Any Brand Tyre Vendor
Partial Wheel Covers
With Brake Only Traction Control
With Manual Clutch
With Radio Pre-Equipment Pack 2
4000 Series
With Interior Courtesy Lamp
With Front Headlamp Levelling
Chug
Postby Chug » Tue Jun 05, 2018 9:28 am
ozzy69 wrote:Hi can i get my etis for both sc56vyb and nj06nnr the first one is my doner mk7 for my mk6
Transit 2006-2014, Duratorq TDCI 2.2 (85PS), Frozen White
VIN Number: WF0XXXBDFX7C74641
Registration Number: SC56VYB
First Registration Date: 01.02.2007
Primary Features
Build Date: 05.01.2007
Series: 260S Series
Engine: Duratorq TDCI 2.2 (85PS)
Drive: RHD FWD
Axle Ratio: 4.23
Territory: (+)"GB"
Paint: Frozen White
Minor Features
With Medium Roof
Low Door Height
With Full Partition
Complete Vehicle
Less Trim Pack
Marketing Level 3
Seat Pack 22
Fleet Key
Less Float Mounting
Less Transfer Case
Less Reverse Proximity Sensor
Ice Feature Pack 2
VIN Number: WF0CXXTTFC6L76446
Registration Number: NJ06NNR
First Registration Date: 01.03.2006
Primary Features
Build Date: 07.01.2006
Cab Style: Double Cab - Goods Vehicle
Engine: 2.4L Duratorq DI (90PS)
Drive: RHD RWD
Axle Ratio: 5.13
Territory: (+)"GB"
Interior Fabric: Stylize (-G-C)
Minor Features
With Low Roof
Marketing Level 3
With RH 2nd Row Fixed Window
With LH 2nd Row Fixed Window
With Roof Height Feature Pack 4
With Door Map Pocket
Passenger Door Trim - Level 1
Passenger Lrg Head/Long Arm Mirror
With 2nd Row Bench Seat - 3 Passngr
Fleet Key
With Driver Air Bag
With Manual Clutch
4000 Series
Chug
Postby jonb1985 » Tue Jun 05, 2018 12:39 pm
Hello, I'm new here, please can I have the details for my transit mk3 based camper van, reg H141KBL?
Many thanks!
Jon
jonb1985
Postby ozzy69 » Tue Jun 05, 2018 9:28 pm
Thank you very much appreciated
ozzy69
Postby Ardtec » Wed Jun 06, 2018 11:34 pm
Hi
I'm new here can I get details for my van please
VIN WF0XXXTTFX7P64342
thanks
Ardtec
Postby Chug » Thu Jun 07, 2018 9:08 am
jonb1985 wrote:Hello, I'm new here, please can I have the details for my transit mk3 based camper van, reg H141KBL?
Many thanks!
Jon
We are sorry, but no information could be found for the VIN/Registration number you entered - H141KBL
What is your VIN number Jon?
Chug
